1/35 Meng 'Toyota Hi-lux' Libyan Technical pick up with ZPU-1 Anti Aircraft Cannon..
langy71
So After my Israeli M6 build I was at a loss as to what to build next, maybe a little bit of burn out.....so upon sifting through the stash I spotted a quick mojo booster....the Meng Toyota pickup truck I bought a few months ago...so I set to work with what I thought would be nothing more than a quick mojo booster....famous last words an 'all....
61c1bt-cr6l-_ac_sl1091_-jpg.465793
The Pickup is built, painted and partially weathered already, pictures to follow,
so for now here's a few pics of the ZPU..
(I may end up removing the bracket 'where the sight is fitted', I left it too close to a heat source whilst attempting to dry the paint, and it ended up warped)
Interesting one Chris,
I reckon that sight arm can be persuaded to get back into position with a dab of super glue eh?! ;)
I saw this kit a while back in my LHS and was sorely tempted,but as it's not really my genre I didn't take the plunge..... I look forward to seeing the whole thing :)
I might have a go at straightening the bent bit Andy, although I have found a picture of an Israeli version of this cannon with no sight unit, hmmmmm,
any how a few pics of the actual Pickup.
Not sure about actually using the base it's on unless I can come up with a realistic way way to change it from a european farm wall to a more 'middle' eastern one..... watch this space... need to finish of a couple of things and then contemplate if I add a figure or two... or leave it as it is... hmmm decisions.. decisions!!
Anybody know what 'to victory' would look like in arabic? ... I've got the urge to freehand some arabic quotes on the sides to break up the overall flatness of the body.
That's seriously nice weathering Chris. really does look good.
Use Google translate I just tried and the results will test your freehand
Google translate may help.
WOW thanks for sharing ,people ask what inspires ,I always think if it makes me think wow then ive been inspired ,not to copy or build one just to bash on with what I'm doing thanks for showing. Dave
Yes, yes, lovely work Chris! Superb detailing and weathering and the dio base sets it off beautifully. Top drawer stuff.
It brought back memories of the one I did in 1/16 RC, mine was a African countries rebal version, nowhere as good as yours.
you might not have to do it in arabic :smiling5:
i follow a motoring channel on youtube called vinwiki and funny enough this vid was on only this week
Lovely work Chris. I'd mount the gun on a skid that can be bolted to the bed rather than depend on the gate. Untrained gunners likely use tracer and shell hits rather than open sights for guidance. Paint should do the trick on the base.
Any pics of said 'skid', i did think of building a base for the gun to sit on, but haven't given it much more than a passing thought..
Thanks for all the like and comments folks,
gonna hopefully finish of a few things on this during the week..
Something simple, maybe angle iron frame you could bolt to the bed with some eyebolts or hooks to attach a cable to move it out of a failed truck into another. Nothing real fancy, maybe some stand-offs to allow firing to the side over the bed sides.
Thanks for the idea @minitnkr, gonna have a ponder about it.. :thumb2:
been back to the bench today, just to start the finishing bits.... had a play with a bit of 'dust'..and came up with an idea for fastening the flag down..
I'm not sure the 'dusty' side windows portray a half opened window properly, maybe I need to attempt to somehow add some streaks......
Before.
After...
