1/72 Airfix CAC Boomerang
flyjoe180
Earth
While I waited for the varnish to dry on my P-47, and continued to ponder the scheme for my Ju52, I pulled this little kit from the ancient stash and decided to start it while I was on a roll. I know a few of these have been made in recent times, so there was a lot of research already done, so thanks for sharing that information on your build threads guys, particularly Tony. His thread is here: http://www.scale-models.co.uk/planes-helicopters/15468-airfix-1-72-cac-boomerang-under-construction.html
I noticed from your thread Tony, that your Boomerang had a reasonable fit. Must have been a lucky draw there, because this one was not pleasant to fit together.
Ready for filling and sanding. I was perhaps premature in putting my Aussie in the cockpit so early, but he did survive the sanding.
View attachment 57592View attachment 57593
The machine gun ports were missing. I decided to heat up the end of a pointed file end and make my own.
Filled, sanded and standing on its own feet. The cannons were a nightmare, but I managed to rescue them.
That was day one complete. Next is a bit of masking, primer and then paint time. I will be brushing with Humbrol enamels. I will be doing the dark foliage green scheme as Tony did, and referring to his research, I will not apply the light colour to the underside.
Thanks for looking!
Love the old Boomerang Joe ,looking forward to seeing the green go on! Nice save on the cannons!
mighty fine looking pilot there,and the bits you are adding will give a bit more to look at
mobear
Nothing like the bits Tony or Trey added to theirs, they were real detailed builds and I was reluctant to do mine after those very high standards. But I have to reduce the stash, SWMBO has an eye on it and I can't expand it. ;)
Great to see another boomer joe, top work so far mate. If you need it i can find the tamiya colours i mixed to get the foliage green , cheers tony
Thanks Tony, I will use the Bronze Green 75 Humbrol as instructed I think, it looks okay so far. No pics today, I have found a few more things I need to tidy up on the underside. I'm not sure if it's just me but the newer Humbrol paints seem to be a lot thinner, which is both good and bad. Good because it is easy to apply smoothly and I imagine therefore to mix for an airbrush, bad because it is so thin it requires many coats by hairy stick.
The bronze green is a good match joe . Although i havent personally had experience of the new humbrol paints ,ive heard a few tales of them being thinner than before . cheers tony
A very nice start on what looks like a small ill-fitting kit Joe
All the filling and sanding was completed yesterday, the underside now looks respectable at least. The main paint work is finished. The exhaust has been painted and fitted and the frame now has a spinner and propeller. I left it for a day to let everything dry well as it has been rather humid here. Should get a coat of varnish on today and some decals, and if all goes well some weathering. Work will get in the way for the next three nights, so it may take another few days to complete.
View attachment 57727View attachment 57728View attachment 57729
Gloss varnished:
View attachment 57738View attachment 57739
A few hours later, decals applied and a second gloss coat applied:
View attachment 57740View attachment 57741View attachment 57742
This must be the first kit I have built that can actually sit inside its box! :)
Nearly there, but some subtle weathering, flat coat and glazing will have to wait until tomorrow at least. Thanks for looking again.
Looking nice Joe, and the rivets are still visible. I like Airfix rivets !
Goddammit............how do you guys get your stuff done so quickly !!!!! And it looks good......I'm off to sulk ;)
And I think I've got one of those SWIMBO's as well - I have an arrangement with the postman, he hides anything that looks like a kit in a secret location for me to retreve at a safe time..........at least I should do !!
Cheers, Neil
:goodidea:
After a wee catastrophe at the end of the flat coat (I dropped it a small distance and the port landing gear came off), the Boomerang is ready for inspection in the completed builds: http://www.scale-models.co.uk/aircraft-pictures/17992-airfix-1-72-cac-13-boomerang.html#post154628
