1/72 Hasegawa Lancaster
So since last time, more torn decals, more swearing but also some progress.
I have done all the props, undercarriage doors and also under carriage before adding it to the model.
Sourced new roundals for wings but struggling to find a replacement for the fuselage. The S on the tail I couldn't find for love or money so just sprayed over it.
Wings black lining on top I have sprayed as decals kept tearing.
More tearing today. Have ordered a full new decal set. The roundals for wings came today, applied them and they went on like a dream!! So must be age of the ones in the kit which I think looking at it are 2007, so coming on 20 years old.
So next I ordered a new decal set. Had to spray out the one side but it's for the best.
Does anyone know, did they have different registrations on each side of the fuselage? I only ask as the decal sheet I have seems to indicate this (see below). Any help appreciated as I want it to be almost accurate even if not completely.
Anyway as I have got as far as I can before more decals arrive I decided to start making a base.
Hopefully it's going to come together in the week or 10 days.
VERY GOOD GOIN there James this will look great pity about the decals but glad you are havin another go at it keep it up an you will succseed
chrisb
No — the letters indicate the squadron (the group of two) and the plane in the squadron (single letter), so it would be very strange for a plane to have two different sets at the same time. But as I said in your other post about this, ISTR there’s a restored Lancaster that deliberately has different codes on it, and the decal set is probably for that one, not for a wartime plane.
Continue the base today, made it more of a plinth so there's space for wiring and batteries etc.
Also used grout on the top this time as I assume it will work ok and as I already have it it's free rather than buying more stuff.
So played about a bit more today. Fitting wiring etc isn't the easiest as I am only using stuff I have as I'm making a point of buying anything that isnt essential and all my connecting wire is 2.5mm core i had left iver from the shed.
The plinth has made life a lot easier as opposed to routing channels for wires. There will be a 9V battery and switch mounted outside and actually with all the LEDs onto it it means they are a little dimmer which I like as it's a smaller kit.
Also managed to get it primer today which I am pleased with. Couple of hours with an airbrush and it will be done.
James just had a catch up, great work so far pity about the decals letting you down. The base lighting is very good.
Thanks, it's coming along ok but really I think the kit is 2007 so to be expected, the new decals are spot on, doing it as "Just Jane" (even though upper gun turret will be a little out of position).
Base black now, ready to have slabs etc scored out before Moe black and then airbrushing in details.
James the leds look great should look brilliant with the reflection off th lank brilliant modeling my freind an i hope you light up you next plane
chrisb
Great work James and at such a rapid pace. The resin flaps add a lot of interest.
Looking forward to the rest of the build
Paul
Beyond a bit of messing about not a lot done to date. Have done a bit more with the base, glued of some gravel that I will paint over and also scored the concrete blocks.
As for the model I have started applying some decals though only had 30 mins spare so not masses done. The builds at that stage where I just need a decent few hours to break the back of what's left really. New decals go on a treat! I have not yet glued in windows as I want these clear and am too lazy to fit and mask them all.
Weathering done and taxiway lights and surrounds for these fixed in. Grass to do and then the taxiway edge lights.
LOOKS VERY good that concrete very real an the lanc on itbe nice to see it all lit up great stuff
chrisb
Starting to pop in the lights, still another 7 to go in round the edges but starting to look ok I think. Pleased with the little inserts around the LEDs, look quite realistic.
BRILLIANT MODELLIN James that concrete looks real very well done my freind
chrisb
