This is my second helicopter built and the first time using putty, as you can tell from the photos. I am no photographer by any means and I hope it looks as good on screen as it does in person, I am happy with the way the model turned out despite some errors I've made.
The only issue I had with the kit is the cockpit; the interior went together great, but the clear canopy (?) piece that goes in the front did not fit well at all. I had to sand down one side so it would semi-blend into the rest of the front. The windows are also glossed over since it was my first time also using a clear coat, and it was semi-gloss so it gave it that effect.
My next build will most likely be Tamiya's 1/48 Mitsubishi A6M3 Zero Fighter (HAMP).
Top down:
Top down:
