1/72 Revell Flower Class Corvette
Wow, the detail on these is amazing, just had a quick catch up and look forward to seeing this one progress.
Terrific detailing Graham. This really is outstanding work. Looks like it went together all okay??
This is looking great Graham.There's lovely detailing on those deck fittings.
Are the Great Little Ships parts the same as Pontos?
Jon.
Jon.
Thanks. No Pontos are a far eastern firm, dealing mainly in 1/350 and 1/700 scale ships, not too sure where they are based, but Great Little Ships are a firm in the UK specialising in larger scale models.
Hi Graham
You're certainly making the most of this. Very neat build and stunning detail.
Since the last update I have been working on the shell holders that go around the 4" Gun bandstand. There are 36 of them, each one takes about 1/2 an hour to make. So I only did a few at a time as they were very frustrating to make. Here they are ready to be primed. The 2nd photo shows a couple of ammunition boxes, which will be used on the bandstand instead of a couple of the shell holders. The shell holders are made of 3 parts the back, the front part which needed 6 bends to get the correct shape and the bracket at the front for supporting the shell.
View attachment 315215 View attachment 315216
Just had a catch up. Excellent work going on here. This is going to be a stunner when you finish it...by the way, what solder are you using? Carr’s 145 and phosphoric acid flux would love this build....
Thanks. Yes I am using Carr's red flux and 0.5mm solder for the larger bits. The ammo boxes are soldered as are parts of the bandstand.
A great deal of miniature madness. Hopefully no burning accidents with the solder. Great stuff:thumb2:
Yes there was a lot of cursing. I nearly dumped the lot and use the plastic ones. Ihaven't burnt myself yet, but I have a lot of soldering to do.
Catching up with the build Graham. Looking very nice indeed, a lot of intricate detail work
Hi Graham, just had a catch up, good progress. Will keep an eye on this as l have just purchased this one myself. Probably will build out of the box, but looking forward to starting in the next few weeks.
Good luck.
Alun
Great metal work. Shaping up beautifully. Donald Duck appreciated. PaulE
