1/72 Trumpeter T62 {ST}
SimonT
Hello folks - this is another current build that I am on with
I have been waiting a long time for a good T62 to appear and bought two of these as soon as it was released - unfortunately it is not as good as I was expecting
A bit of work is therefore required so here is a catch up to get to the current state......
Turret stippled with Squadron Green Stuff to get a bit of texture
View attachment 300331 View attachment 300333
Front wheel arches cut away and track guards thinned right down
Engine deck grilles cut out, louvres installed from micro strip and mesh covers added
View attachment 300334 View attachment 300337 View attachment 300335 View attachment 300336 View attachment 300338
One of the worst features of the kit is the shortcut they have taken with the turret ring where it hangs out over the track guards
This should be a sloped casting from the hull, widening out at hull top level
It has been moulded as a solid lump with vertical sides rather than the more usual method of providing the sloping pieces as add on parts
I removed the moulded lump and rebuilt things with Green Stuff and plastic card to get the correct sloped sides
View attachment 300339 View attachment 300340
Hull with turret after rebuilding the sides
View attachment 300341 View attachment 300342
Gun barrel replaced with a scratch built item made from tubing and filler
View attachment 300343 View attachment 300344 View attachment 300347
The kit fuel drums are not great and lack detail so I scrapped them after cutting off the drum racks
New drum made from tube, brass wire, pewter and filler and strapped down to the recovered rack
For a bit of variety I left off the left drum and made up empty retaining straps from copper sheet
View attachment 300346 View attachment 300345
Raised lip added around the turret ring from micro strip
Solid exhaust carefully opened out
Handrails added to turret from brass wire - nothing provided in the kit
Cont.......
........Cont
I decided to open out the other grille at the rear left side - this would have been better to do earlier before the hull halves were joined
View attachment 300351View attachment 300354
Stowage box with added latches - first attempt was rubbish so they came off and were replaced
more handrails
mantlet cover sculpted from Duro Green Stuff
More handles
View attachment 300357View attachment 300358View attachment 300359View attachment 300360View attachment 300361
Fuel pipes added along with tank fixing brackets
View attachment 300362View attachment 300363View attachment 300364View attachment 300365View attachment 300366View attachment 300367
Details added to the front of the turret - light bracket thinned down and bolts added, lifting mechanism made from brass wire
Lenses added to the little marker lights next to the fuel tank
Hull front cleaned up and filled
Cont..........
.......Cont
Splash board added to glacis plate
I mucked up the cupola fixing ring and had to make a new version
View attachment 300373 View attachment 300374 View attachment 300375 View attachment 300380
Extra details added to gun barrel and mantlet
View attachment 300377 View attachment 300379
Random pictures of the back end again
View attachment 300371 View attachment 300378
The one piece moulded track units could have been better. The track pins are rather vague so I added new ones from punched pewter sheet. Finished doing them today - takes a while
View attachment 300376 View attachment 300381
So this is where I am up to now after adding the track pins and front and rear hull tow hooks
Still needs front lights, rear marker lights, fuel tank handles, storage box latches and one or two other small details
SimonT
More done on this one today
Handles added to fuel tanks and marker light added to rear hull side
Bolt heads added to final drive housings and rear marker light added to hull side just above track guard
View attachment 300533 View attachment 300536
Front mud guard torsion springs added
New conduits to lights from lead wire
Light cages added from brass wire
Un-ditching beam holder straps added to rear panel - bracket recovered by cutting off the kit 'log' and trimming down
I think this is now done and ready for paint but will give it the once over first to see if I have missed anything off
SimonT
Morning Simon
What you do is way beyond what most of us would dare tackle. A great model. I still wonder why you bother to buy kits at all :tongue-out3: Paint next :thumb2:
Just caught up with this build Simon, and may I say what cracking work your doing, I don't think there isn't any part of the kit you haven't changed in any way ( and for the better ). This is one to keep on watching.
Thanks Neo - your friends 1/35 T62 is not scratch built (lost something in translation? ) but it is super detailed. Very nice
Hi Jim - it should have been better as a kit. They could have made a really good job of it if they tried. I bought two so I will get to do this all over again at some point
Ian - thank you very much. You're correct, not much that hasn't needed some work
MrT
I am glad you are continuing with this build. I expect you will be glad when you can finally get round to painting it
Unfortunately we don't have in Russian word like scratch, so I used it. Sorry for my mistake. I don't use traslaters because studied English for several years.
Steve - very nearly at paint stage. I need to add some turret lifting hooks and then I think it can move to paint
Hi Neo - no worries. I just had a different idea of what to expect when you said scratch build
Looks like you had some pent up T-62 modelling energy to uncage. Well done!
Hi Jim - I was annoyed at how bad the kit was and just sort of went for it :smiling:
Watching Simon's work over the years reminds me of a diamond cutter with a rough. He sees what could be, then makes it happen. PaulE
Hi Paul, thanks for dropping in
Have added the turret hooks now.
Also realised that I had forgotten the screw down latches on the stowage boxes - have added them to one box but still need to do another so still not quite at paint yet
when the game starts to get hard Mr T starts to play. Always a joy to follow your builds
Simon .
Of course the first thing I notice is the time of postings. You now seem to be waking up later at the table or embarking on very early starts.
That said it certainly doesn't comprise your work.
John .
1/72 Trumpeter T62...number of kit parts...2...after Simon has had a go at it. :tears-of-joy: Wondered when the painting would start...respect.
Marcello, Ross - thanks for dropping in
John - it's been getting worse. Waking up later and later - been getting to bed around 4am for a few days then it was 5am this morning!
I did however manage to get some more done on this before I passed out
I found a few more details that were missing
Each fuel tank needed an extra drain plug (?) adding to the end
Cupola got a brass wire handle to replace the solid plastic one and hinge pin ends added
Three lifting hooks added to the turret (just in front of the grab handle - same at the other side and one at the rear)
These were made from cut down and sanded Airwaves 1/35 etch equipment brackets
Front left stowage box lid fixings added
Hinge points added to the fender torsion bars and the fender lock bracket added made from an off cut of etch fret brass
Rear left stowage box lid fixings added
A sprinkling of rivet/bolt heads added and I think this is now complete and ready for some paint
SimonT
