1/87 Scale Ukraine Ambush Dio
Or put a zipper on it.....BTW, if you hold off on this dio a little longer, you will be able to include Bradleys and M1 Abrams as well....just thinking out loud. ;)
On it Rick. I guess they figured out the fuel situation for the Abrams. Would expect them to be deployed together like Leopards & Marders.
Here are some from the standby stash. This is just for show, not part of ambush dio.
Artfully compressed.
.....or could be an attack through a defensive position.
Selected armatures for trees to thicken up hedgerows for additional air cover.
Another view of selected armatures for the north hedgerow.
You really do have a flair for these dios. Your photos show just how realistic this is.
Thanks guys.
Trees in north side, undergrowth next.
Eyeball view.
C&Cs encouraged.
Great work on the vegetation Paul , love that last photo .Those plants heads you use definitely suit your scale .
The difficulty w/reusing dio bases is removing & replacing vehicles & figs w/o wrecking the gardening.
Undergrowth & motrees complete. Placement of armor in flux. I'll try converting BW PGs & US modern inf. to Ukraine if I can get more Prieser US inf. The search continues.
C&Cs welcomed.
Eureka, I found 15 built Preiser modern US soldiers, they just need paint. Here they are w/Foxes under conversion/construction & additional AT weapons.
C&Cs encouraged.
Old ROCO Dodge & Trident Chevy stepside w/possible Avenger Stinger launcher mount. Almost finished C&C Fuchs. Conversion is very good once you get the pour blocks out of the way. They even supply dimples to start your drill for adding your own wire grabs.
