Having done the 'Woody' last year figured it was time to do the Merc ,first up cleaning the frame up and replacing the coil springs
I used some copper wire coiled around some sprue for the front coils
I used ca to glue them in the retainer cups and trimmed them to the right height
This nasty bit of frame support is the same molding as the Woody I did last year and its a bear to get in place and keep the holes lined up while the glue sets. I learned from doing the Woody to start glueing from the rear and let each section set before going to the next. I rushed this on the Woody and wound up spending a lot of time filling and cleaning up the misalignment,totally my fault.
This time around the patience has paid off and no filler will be needed just a little fine filing and sanding. Started working on the mill and going to keep it basic out of box except the exhaust manifolds,and some detailing such as plug wires and a few fluid lines.
Before I can finish the Mill the chrome needed to be stripped off . I use straight bleach and it really works fast,the stuff literally dissapears before your eyes.
now just pour the bleach back into the bottle and sneak it back in the laundry room and the Missus never missed it!
