This is next on the bench. I'm hoping to increase the amount of work I do in oils on this figure.
I'm waiting for some gel CA to arrive before putting this together. But I have done a bit of preparatory work tidying up, and especially altering the halberd.
The haft is supplied as two resin sections that plug into his clenched fist. The chances of these aligning to look like they're single straight handle is remote. The likelihood that I'd snap them off sooner or later is very high indeed. So I've drilled through the handle and inserted a short length of piano wire, which is hard to cut but very stiff, so no chance of bending it out of shape accidentally. I've then pinned two sections of CA hardened bamboo skewer into place. The spike on top is also drilled and pinned.
