The following two pics show the need for a tricky masking job:
It is a wheel cover, scale 1/16. (In my case, the red will be green.)
For a good smooth gloss paint job (as for the rest of the model) I plan to airbrush with Tamiya Synthetic Lacquer TS14 and TS43 (a spray-can product that I have used for the rest of the model). The problem is, how to mask between the two colours?
Ideas:
A:
1. Mask off all the green except for a 2 mm band touching the interface. This would be done simply with separate strips of Tamiya tape with little effort to make the 2 mm band smoothly round;
2. Airbrush the black up to and over the interface, inevitably on to the 2 mm band;
3. Mask off the black part (but not the 2 mm band). To get a smooth round edge great care would be needed if using Tamiya tape. Or I could use one of those rubbery masking fluids (if they don't pull up paint, but lacquer is pretty hard);
4. Airbrush all the green part
The problem here would be making the round edge in step 4 smooth either with the tape or the fluid.
B: Replace "black" for "green" and Vice versa. Would this be better in some way?
C: If I can't get a sharp non-wavy edge between the two colours (pretty important), airbrush the whole thing black.
D: I've just thought. Perhaps, to get a sharp non-wavy edge, I could use a sausage of White Tack on the black, touching the interface, and fill in with tape over the rest of the black.
E: Or, again to get a sharp non-wavy edge, I have some 1 mm diameter polystyrene rod which I could fix in a circle following hard up to the interface, following the change of surface there, and fill in the rest of the black with tape. But would the rod stay put?
It is a pity that Revell did not make the cover in two parts-easy enough to do.
Any ideas please?
Ideas:
A:
Any ideas please?
