Airfix 1/72 R.A.F. Air Sea Rescue Launch..........'The Sea Shall Not Have Them'
I can remember building this back in the distant past and thought the Oerlikon looked too big? (and the Revell offering in their various PT boat kits too small). Any chance of a measurement? NavWeaps states an over-all length of 87" or 2210mm so 30.69mm in 1/72.
Tom
Sorry Tom, I don't possess anything that will measure to the accuracy you require.
I've put a rule on the weapon and it measures around 38mm. o.a.l.....This measurement includes the gunner's shoulder thingies.
Cheers.
Ron
Ta for trying Ron,
I don't know if the 'real' measurement includes the shoulder frame, but 6 or 7mm seems about right. It could be that at the time i'm talking about I was building a Revell PT boat as well (and thinking of a 1/72 flower class corvette built as HMS Smilax which would have needed 3 oerlikons to replace the kits rubbish ones), maybe that was under scale ISTR (more of an inkling really) that someone once said the Revell kits scaled out nearer 1/80something but don't know if it's true.
Tom
Just found out Revell 'Higgins' PT kits were 1/98 scale.
https://www.scalemates.com/search.php?fkSECTION[]=Kits&q=PT+boat+Revell
Great work Ron, it looks so much better with the decals and numbers on. ( not that it didn't look good without them ).
Thanks Ian.
Here's the 1/72 crew. The boss, two gunners and the Lifebuoy chucker. The Skipper looks a bit naff 'cos he fits in his little hatch a'top the wheel house, resting his elbows....
Cheers.
Ron
Looking sharp Ron, very nicely done. The figures set the build off nicely
Thanks chaps....
Time to do the bases. Similar to my Severn Lifeboat dio., I'll try and make a trilogy. 'Setting off', 'Giving it plenty.' and 'The Rescue'
Setting off. A total cheat for this, the first part. I've quite blatantly, and with no sense of remorse or conscience towards my fellow man, nicked the base from the aforementioned dioramas and placed the Rescue Launch in the lifeboat hole.
I promise the other two stage bases will be new builds.
Next I'll tackle 'Giving it Plenty!'
Cheers, and thanks for looking.
Ron
