Evening Folks and please don't ask........The build is still underway and I'm making progress...First,
Wow!! that happened so fast, I forgot to look! I guess I'll have to stick around for the re-runs.
Rick, you need to stop taking those naps all the time!!! Won't be any re-runs yet, so please stay awake Buddy......
Allen, I missed the start of this thread and I just had a catch up.
Very interesting vehicle and an amazing kit.
I'll seat somewhere, if any seat is still available, ready to delight my eyes. :smiling3:
There's always a place for you Andrea. You might want to wear very dark glasses and bring earplugs just in case I have problems. I wouldn't want to corrupt your morals my friend......
That was a great piece on Captain Alfred Becker Dude 1 , thoroughly interesting. Reminded me of Percy Hobart Major General Sir Percy Cleghorn Stanley Hobart, KBE, CB, DSO, MC .Very similar in their engineering ideas.
He was an interesting man Dude 2. The German problem was the losses on the East Front and the lack of effective anti-tank weapons to repel the Russian tanks. Hobart was cool as he made a lot of good mods to his tanks too. Hobart's funnies come to mind......
Thanks for the ID Allen; the Mossie is temporarily stalled due to my inability to satisfactorily eliminate the nose seam (despite copious amounts of filler and sanding)! However, the Spitfire is Shelf of Doom, the Half-track build is progressing well and I intend to finish both within the time constraints! I now realise the problems of over-commitment
Sorry to hear that Steve...Are you getting good bench time or are you still involved in the renovation project with your fine lady??? How bad is that nose seam Sir??? Can you say hammer................
Well Allen that information was well worth a read through. Quite a guy our Capt. Alfred Becker.
You've made a great start and as John said time spent prepping the parts is time well spent.
Thanks Jigs. Between the wars, he had a textile factory and after WWII and his release, he went back to Krefeld and started another textile business which is still going today. Prep with a
resin kit is the only way to go. One has to test fit everything twice before dabbing the CA on it.
Great choice of vehicle. These quirky Brach kits look great. Never ever seen a build log on one before so nice to see what you get for having your wallet temporarily raped
looking forward to progress
Thanks Los. Luciano Brach does make some interesting kits. Got a few more in the stash. They are pricey for sure and my wallet feels raped, but to be honest, I've get a warm and fuzzy feeling while building this. He makes 2 other kits based on the MCG. One with 7.5cm PaK 40 and a troop transport similar to the Sd. Kfz. 250. DES makes a few kits of French 1/2 tracks also. They're very finely cast resin kits too, but with a price......
As to my above statement...I started to finish the front suspension and went about cleaning up the tie rod and the steering arm. One has to be careful as these parts are thin and long to boot. Took a while and nothing got broken with my sausage fingers. I also drilled the steering arms out to fit the pins into them,
One could replace the pins and make the steering fully workable, but if I started that, this build could take 6 months to finish. You know one thing leads to another. I will have the wheels turned to one side and CA everything in place. The tie rod pins, when in place in the steering arms, are 0.3mm too far apart and skews the steering with too much toe-in. No biggie, as I can fix that with no probs. I then went about removing the 2 stabilizers between the differential and the rear suspension mount last night. In doing so, I touched one of the fasteners for the motor side panels and it fell into my lap or so I thought. Hence the "don't ask" from above. One of these,
Many foul words and an hour with my LED flashlight, on my wood laminate floor looking for it, NADA!!! The piece is 2x3mm and gone. I even checked inside my Nikes, but it was nowhere to be found. Ok, plan 2......I have a collection of a similar pieces from Dragon kits in my spares, but where??? Spent a lot more time looking for where I put the damn things and finally found them, along with my collection of wing nuts too. Unfortunately, they are shaped the opposite of the one above. I spent a lot more time today, after work, looking all over the floor for it again. No luck, so I'll just modify one of the Dragon pieces to use......I was not amused over this.....
Tomorrow, weather permitting, I want to AB the driver's interior, the underside, the track/suspension components and other parts. My order came today with fresh paint. I have been masking off the glue points as I don't like to CA painted parts together. Glue resin to resin and then do touchups as needed. Enough waffle for tonight folks..........
Update morn, with luck. Thanks for looking in and all abuse is welcome and cheerfully accepted...
I've posted some pics of other resin kits of French (Becker built armored and Normal) 1/2 tracks below. Not cheap, but very nicely cast and worth it.....
Allen
Brach Models
DES Kit
Food for thought...........................................
