Hi all
So this is something that Si hinted at in a previous post.
This is another idea we got from the Terrain Tutor (link). Stylised hills/rocky outcrops for our battles - made from that expanding insulation foam you get in cans.
Process is as follows:
ACW as usual.
How The Terrain Tutor does it
Junior squirting out and the result once set:
Our attempts in chronological order. The last one was almost entirely Junior's own work.
- Squirt out foam as desired.
- Shape to your wishes and glue to a base.
- Cover in polyfiller and grit to your taste.
- Paint using kids or household paints - a base coat of dark grey following by 3 coats of dry brushing 3 different shades and colours.
- Add flock and foliage to your taste.
- Job done!
ACW as usual.
