Andrew's 88mm Flak 37 (The Hunters and the Hunted)
adt70hk
Morning all
So having finished the Corsair a couple of weeks ago, I was deciding what to do next when my gaze fell on this. As it was sitting on my modelling table, quite simply because there was no room left in/on the model cupboard or indeed under my table, I decided this would be my next victim - if only to get it off the table!
This is also a return to my collection of 1/72 kits and reference material in some way shape or form connected to the British WW2 bomber offensive, with the title being as above - 'The Hunters and the Hunted'. If you want to know more, the below links take you to the the collection and completed builds thread.
Now this gun, in it's various guises (Flak 18/36/37) aka the 88, needs no introduction and to my mind is the most well known AA/AT gun of the war, and rightly so given it's pedigree. In the context of Bomber Command's offensive and therefore my collection on the topic, it is of course my much in the 'hunter' category.
At the moment, I also plan to do it on a small base something along the lines of the below pics, not something I have done before and so will be something new. If I do go down that route I also need to source a crew for it because the kit doesn't come with one.
As I've been off work this past week, I've also managed to make quite bit of progress - pics to follow later.
ACW as usual.
ATB
Link to the collection of kits and reference material: https://www.scalemodelling.co.uk/fo...-the-hunted-kits-and-reference-material/page2
Link to the completed builds to far: https://www.scalemodelling.co.uk/fo...4-the-hunters-and-the-hunted-completed-builds
The obligatory box art, desctructions and sprue shots....
Ideas for a possible vignette
Ok chaps, so quite a bit of progress in the past week or so. It certainly helps that, unlike planes, there is no cockpit do before the main build process.
Summary of my initial thoughts so far:
Pros
- A lot of nice detail, including elevation cylinder pistons that can move in and out as you change the gun elevation
- Minimal flash (other than some horrendous flash on the sprue frame that had me worried)
- Generally very good fit
- Good instructions
- A lot of kit for your money...effectively five-ish kits in one - the gun, the two wheel bogies, the rangefinder and the trailer for the rangefinder.
Cons
- I don't like the plastic....not quite how to put it but feels a bit soft and soapy...but does hold the detail well nonetheless
- Quite a lot of seams lines, pretty fine on the whole but obviously still need to be dealt with
- Bad sink marks on the rangefinder tube in the worst possible places......the top and highly visible rear
- The way the barrel goes together makes it hard to get it straight and deal with seam lined and join seams
Build and painting strategy.
- As this is going to be in a fixed AA position rather than being out in the field possibly facing the enemy I will forego the shield, as per the above pics.
- As the gun is quite a complex shape, I will spray it in sub assemblies as I don't want to risk flooding the kit with paint in trying to reach a hard to get to crevice.
Oh and the figures I got, look very good on initial inspection. There is some tidy up needed but nothing major upon first inspection. The only real issue, is that they're clearly geared up like troops out in the field but as they're the only one around I will have to make it work.
ACW as usual.
ATB
I had a heard attack when I saw this flash......but fortunately it only on the sprue frame.
The way the end half of the barrel goes in makes it hard to get straight but I think I have managed it.
Figures look ok.
Progress shots of the gun going together. The shots of the assembled gun are with it just dry fritted.
Rangefinder...sink marks and all....plus trailer
Ok chaps, so the construction phase is now pretty much complete now that I have done the travel bogies and the associated wheels.
There a couple of small bits that need to come off the sprue but as I will be painting the separately ahead of final construction, they will stay there for the time being. I have also left some bits and pieces off until final assembly as they will make painting much easier.
Other than the tow arm, the bogies are virtually identical and as you can see they're reasonable detailed on the underside too. The solid looking wheels will sit on the inside of the wheel configuration, in what will be a pair on each side - hence they're being 8 wheels in total.
On the whole they went together well, although moulding on one of the bogie frames was bit iffy places. There were also quite a few seam lines that had to be dealt with. I'm also in the process of dealing with the sink marks on the range finder.
ACW as usual
Ok chaps, so after two weeks of no activity, the kit is ready to see primer.
As it has lot of small nooks and crannies when assembled, I have decided to spray in sub-assemblies to hopefully reduce the risk of flooding it with paint when try to reach those out of the way places.
ATB
Excellent work Andrew 👏
I must say as a WW2 RAF/USAAF enthusiast the subject really gives me chills but it looks great nonetheless 😉
Geoff.
Looks good. Strange to see that amount of flash just on the sprues. Nice progress.
Geoff.
Geoff....I know exactly what you mean...especially as in the war games my sone and I used to do, he had an 88 in anti-tank role........😓
Jim - completely agree about the flash. When I saw it I had major scare but as I said it was all good in the end!
Thanks again chaps!
ATB
Good morning all
So just a short update. Primer went on yesterday afternoon - a mid-ish grey. I used Vallejo's very light grey primer and black at about 3:1 to get the colour I was looking for.
Paint to follow in due course!
ACW as usual.
ATB
This is coming along a treat Andrew
Andrew, all looking great mate.
I wish I could get the predictor unit in 1/35 :( Coming on superbly!
Belated thanks chaps. Glad you're liking it.
The Panzer Grey flew last weekend but there were a few hard to get to spots that I missed and I only had a chance to get it done today. Pics will follow in due course!
Thanks again for the support.
OK chaps, so the main gun and accompanying bits and pieces are all painted, and the gun is assembled
Have to say that German grey is a very boring colour....and it also turns out that I think this is the first dark grey scheme I have done since coming back to the hobby.
I did lighten it a bit with a drop of tan given the scale I am working in but it is still very dark...it also turns out that it almost exactly the same shade of grey as my usual tyre colour, so it doesn't look like I have painted the tyres even though I have.
One nice touch with this kit is that the pistons actually go in and out of the cylinder barrels as you alter the angle of the gun barrel. The cylinder end has been left hollow and of a large enough diameter to allow the piston to move in and out without stripping the paint off. It's not perfect though as the piston attachment point on the barrel cradle is a simple bit of styrene sticking out from the side and so they do sometimes pop off - but nonetheless a nice touch.
I have also started work on the Peddinghaus-decals aftermarket crew.
On the whole the quality is generally ok for this scale. However, upon a close inspection yesterday as I started to clean them up, I realised that one of the seated figures has his right hand missing. I nearly let it go but sent Peddinghaus a message yesterday on the off chance.....and within the hour I had received a reply apologising and saying they would send another in the post, so all credit to them.
The rest of the figures have all now had a coat of primer ahead of the painting stage. The uniforms are very much of the earlier war type, so field grey will be much in evidence when the colour comes out.
ACW as usual
ATB
PS...and as well as being boring....dark grey makes it hard to get decent images given the shadows it creates.
The pistons fully 'in' with the barrel elevated and then 'out' when the barrel is depressed....hope you get the idea
The figures.......pre-clean up...missing hand and post primer
I must confess to being impressed with your work and the kit itself. Great detail for the scale and a very neat build. The figures look excellent and well done Peddinghaus for good customer service.
Thanks Jim. Glad you like it and as you say great customer service!!
ATB
Ok chaps....so a bit of an update at last.
So this hit the doldrums at the beginning of the year, in part because before Christmas I wasn't happy with how the figure painting was going (I'm a bit out of practice) and then I was really sick over Christmas, and then I picked up the Spitfire in March to get the mojo going.....you get the idea!!! 😉
Anyway, I have been plodding on with the base for the vignette, primarily at model club meetings and so as there are only two a month, it's taken a while to get where I am:
  • As it's my first base, I'm using a cheap picture frame to keep it simple...nice and square and the frame defines it nicely
  • The base needs to be reasonably robust given the nature of the emplacement but I wasn't going to go and spend a lot of money.......so I used what I had to hand.
  • I therefore used the thin MDF board from the frame and another piece I have, and sandwiched a piece polystyrene sheet between the two.....after all it won't need to take a lot of weight.
  • I braced the underside to reduce warping...which has largely worked
  • I based my design on one layout I have seen online...if not slavishly so
  • Sketched out the design on a sheet of A4 paper
  • Taped the design layout onto the MDF board, which was helpfully also A4 in size
  • Then used the design as a template, drilling and scoring through it directly onto the board to give me the layout on the board
  • As you'll see the wooden structure is made out of a combination of cocktail sticks, bamboo ear bud sticks, matchsticks and coffee stirrer sticks - I'm going for a hotch-potch of an emplacement.
  • The coffee stirrer sticks are about twice the width at this scale of what I have seen in the pics and I would expect to see in real life, and so I score a line down the middle of each one, to hopefully make it look a bit better...I am not cutting them to scale....that is just too much effort!! 😂
As you can see, it has a long way to go but will hopefully give you an idea of what it will look like.
ACW as usual.
ATB
My inspirations
My design template......you can see where I drilled and scored through it onto the board
Going together slowly......the red circle on one image is where the crew shelter will be.
You can see that I deliberately left the supports far too long...no point cutting them too short at the start and causing myself problems. They can easily be trimmed at a later date.
The base structure and bracing
Hi looks great, can I ask why you have done your base like that?, eg: what looks like hardboard, then foam, then hardboard again, so a sort of sandwich structure?
I like where this is going mate.
Thanks Scottie. Coming from you, I'll take that as a compliment!
Hi Peter
Short answer is necessity.
Ideally I'd use a nice solid lump of wood but I don't have one of the right size and am not going to go and buy a big slab for a one-off, plus I don't have the tools to cut is accurately. Also, the picture frame gives a nice definition to the landscape area.
The MDF board is the back board form the frame but on its own it will easily warp once I start using PVA and similar to do the grass, plus I need some depth to push the uprights into to make sure they stay in place....creating the sandwich seemed the best way of having enough rigidity depth given what I had available. It also has the benefit of being much lighter than a lump of wood!!
Hope that helps?
