Andrew's wife's 1st model - 1/72 IBG Pz IIIa - should I apply a filter?
good on her,so glad to see it,job well done ;) :smiling:
OK?? OK?? is that all you can say? :rolling:
That's an excellent result, first model built, first time using airbrush ?
(That was a practice run with the undercoat).:thumb2::thumb2:
Spent most of my modelling trying to get that kind of result! ;)
Now for the tricky part - a little weathering perhaps??
Paul.
:smiling2:
You got to hand it to the good lady Andrew she's damned good .:thumb2:
I like that!!! Way better than my first attempt. :thumb2:
Rick H.
Nice job. Better than my first attempt as well!
Great job mrs andrew , youre a natural , cheers tony
Same here I dint do a good job got the shakes on the first an last attempt as I borrowed a friend A/B an I though It was rubbish so Andrew your good lady is good :thumb2:
chris
All
Thanks for the great feedback and for the support I'll make sure she reads the comments later!
Paul - You are probably right about my 'OK' above but you have to understand that I have made understatement something of an art form! In fact if they allowed pictures in dictionaries you would just see my face against the entry!! ;) I will therefore try and be more effusive in my praise of her efforts in future posts!! :smiling: Next up before weathering is painting the tools and tracks.
Thanks again all for taking the time to respond.
Yours
Ah yes I know how that goes - first it's a model - then it's the bench - then the stash!!
Need me to go on???? :flushed: ;):smiling2::smiling2::smiling2:
Paul.
:smiling2:
Thanks Paul. Much of appreciated. I'll make sure I pass your comments on.
ATB
Hi all
So at some point in the process I was thinking of applying a lighter grey filter to lighten the tank up a bit as the base colour is a bit on the dark side and also to blend the brown and grey a bit better.
I've only done a couple of times and so am still very much learning about them and how they behave.
Am I on the right lines or would another approach be better?
Thanks always in advance for your ideas.
ATB
