Antonov An-2 (Revell, 1/72)
little dry fit of upper and lower wing
till now not a drop of putty is used
Roman
Another fine looking build in the works Roman,the office looks great!
I have manage to do joint of lower wing and fuselage. I see same thing is waiting for me for upper wing and canopy.
All panels on lower wing and fuselage are rescribed.
Must have also putty time on engines cowel.
Here are some pics from my work... upper wing, canopy and engine are still on dry fit.
Roman
Looking good. That canopy looked a pain to mask! Those joins look like they will give you and the putty a good work out!
Here I have one tip... I dont know if any of you work like this... Tip is for filling gaps between canopy and fuselage.
I use WATER BASED glue for wood, who is dryed became transparent.
With toothpick put drops into the gap untill is filled up and little overedge and when I finish with filling gap right away moisture with mouth cotton swab (for cleaning ears - dont know on english... i think is cotton swab) and wipe away excess untill stay only ammount in the gap. After drying you will se clear transparent fiulling.
If neccesery replay all... because somethimes with cotton swab you clear little more from the gap.
Next time when I will do this I will make video tutorial
hope you will see different on pics and model of glue.
BEFORE:
AFTER WATER BASED WOOD GLUE:
and must say gap was not like before on my post, upper wing have little too mutch bended canopy, after I was glu it I see gap was not too big, but was present... arround 1/2 - 1 mmm
Hope I help with this tip
Roman
Thats a very good tip Roman and one I will be trying :bow:
yaa awsome tip and one i would never have thought of thnx roman
engine, upper wing and upper wing carrier are glued, all is putty and sanded and preparation for rigging is under the way
Thats all for today :)
Good night and cheers,
Roman
Looking good, what method do you use for rigging? I really need to learn how to do rigging.
For first time I'm trying the method to drill holes for rigging thru the wings. I have drilled with 0,4 bit and thru holes put fishing line 0,16 mm.
After that I will with CA glue the base of slings and on another end tension with hand...
Will see how will came out :)
Roman
prop and wheels are dry fit...mybe little few thing to correct on the model, but generally this is it... ready for priming
Roman
Looks a good one to me. I have one question though. I see that you have already rigged it. How does that work out. Painting after doing the rigging. I can see me having all kinds of problems doing that.
\ said:
Looks a good one to me. I have one question though. I see that you have already rigged it. How does that work out. Painting after doing the rigging. I can see me having all kinds of problems doing that.Ian M
hey Ian,
I have decided to do rigging before painting because it will be one color scheme... white all over, exclude black in fron of canopy... sun glare protection...
and only because that I have decided to do rigging befor and not after...
Hop I will succes in this
Roman
More brilliant building here Roman.
Wish I had your confidence, my builds seem to take ages in comparison.
I really enjoy watching you create.
Tony.
generally this is it... few more details ... and is ready for gloss and decaling
Cheers and good night to all
Roman
Crank'n right along with this one Roman its looking great!
