'....a small charge......' good grief you are that tight you could not even put the 'a' between the 'm' and the 'y'.....Jim, settle down for a long night , hot chocolate at 2300 , breakfast at 0900 . Blankets are supplied, a small charge my be required.
John.
Thanks Jim, going to have a go today.Hi John
A real mystery. I hope you can figure it out. I built an Eastern Express kit of a BA-6 armoured car and although not the best detail it went together ok.
Good suggestion Rick, do think it's something I've done as can't believe a kit would be available if it was so wrong .JR, if you have the specs. Check the wheelbase and overall length of vehicle and see if there is a discrepancy. At least you will know where the fault lies. Rick H.
. Cheers Steve , i've just put in a bid , never know my luck.
Thanks Jim, will put some on tomorrow. Will be interesting to see the difference if my bid for the Vision Model wins. Still have my name down with E models ,so all's not lost.Looks like you have gone a long way to sorting it. Just some filling and it's done.
Your lucky Paul, it nearly ended up on fire !Chair pulled up and Like Peter just to sociable you understand I will have a slice of each that should see me to when the build starts.
