As the title says , well I just got an AB set aerosol type and it works fine but you lose too much pressure when the can goes below half way but I also think the AB is at fault as it uses a system of pushing air upwards instead of along a tube
This is the one I've got very basicView attachment 82954
Now this is fine I get good cover and smooth finish but the drop of pressure causes a splutter which then ruins the finish.
1st would this work better with a compressor ?
2nd is this a flaw with the design and the better tube with paint pot on top be better.
3rd what is the best paint to use , I've used humbrol and revell acrylic so far and found that it does dry very quickly and blocks the nozzle at the top of the paint pot
Any help is greatly received thanks
