- Joined
- Apr 27, 2018
- Messages
- 15,197
Chris,
She is looking gorgeous mate.
THANKS Scottie she now in her warpaint an just a few paint touch up's an then it will be waiting for some decent wather so she can jump into her test tank for all her testsChris,
HI Jim well i wish i had your confidence on this regards leaks but i will soon find out as she will be in the test tank soon for 3 hrs an she will first undergo the water pressure tests as she will be loaded up with about 50 pounds of batts to push her over her water line then we will see if the water comes pourin in her but if it does then i will mark on her with a water proof pen to mark where the leak is then a little resin as if theres a hole the resin will find it an seal itHi Christopher
Your update never cease to amaze me. So much work and planning. She's looking superb and of course there won't be leaks :thumb2:
HI Neil yea she comin on soon be time to get her bum wet in the test tank then i'll find out just how well ive built herWow, wow wow!!
Utterly stunning, Chris!
an to you also Bob cheers if she was a stug she would be eccellent lolWhat a stunning build Chris, the amount of detail and effort is truly excellent!!!!
Bob m8 if you look at no'3 pic it shows the big bolts that slip through the holes in the rear section an then its pulled togeather by butterfly nuts an all the eletrics will also meet up by them plugs systems an then when finished sailing (thats assumeing she floats ) i just remove the S/S an then i just undo the butterfly nuts an remove them then gently pull the two halfs apart an then yes Bob you are right she will be standing in the livin room in her cradles stands in two bits till time for sailing againChris
How will you join the halves together and i assume when not sailing the seven seas it will be kept in 2 pieces
