Yes my wife is banned from the man cave,
Great work Chris just had a catch up and really glad to see she floats very nicely.
HI ALL another update but this one is special as im nearly up to the moment of running up the motors as now tomorrow ive just got to solder the main positive an an negative terminals on an ive been working on this nr all week since monday an this has been a bugger to do what with all the heavy duty wireing it makes my fingers hurt tryin to bend the wirein could have used small plyiers but dint want to damage the outer coating on the wires an ive treid to keep the wireing as short as possible an im just a bit worryied that i may have placed the ESC's to close to the motors an they may get to much vibrations but will see on that tomorrow just got to hope ive followed my m8 richards new instructions ok as they are a bit complex but i think ive got it right
chris
well the first pic is of the new wireing diogram from richard see if you guys can understand it lol IMG_6380.JPG
Best of luck with it Chris, fingers crossed for you that it's all good.
an i wired it all up in reverse but so its understandable ive started the wireing on monday by starting to wire up the relay an here is a heavy duty switch that should take the 30 to 40 amps of current an this took all day mondayIMG_6376.JPG
CHEERS Mark im gonna need the finger crossed lark as there is a lot of money that i may blow up but im only gonna take it a bit at a time i think an just fit one small 3 amp fuse in an then see if it the two rear motors will work as this is the BECC system an ive never wired this system up before SO................................................
well here ive just wired up just one ESC that will work the rear motors with the fuse box in an the relay all in the circut IMG_6381.JPG
next pic both ESC all wired in the system an this took two days to get right an the air was pretty blue lolIMG_6382.JPG
an ive fitted in the main switch as this is the only place it could go but if all ok then i will make up a cover to fit over it when sailing as to me it looks a bit of an eyesore IMG_6384.JPG
here is the main fuse box for both sets of ESC's an motors an ive fitted just 3 amp fuses to just try running 2 back motors at a very low speed an if ok then i'll take them out an fit the proper 30 amp fuses IMG_6385.JPG
AN HERE is the knock on switch where ive fitted in a blue 9 gram micro servo to work from the R/C system an the white servo top just swings accross to hit the switch lever an cuts the power to the front set of motors so i can run on two or four motors while sailing for extra sailing time IMG_6383.JPG
AN IF this all works ok then im off to the bow hull section to wire in the bow thruster ESC an the motor but i must remember to fit in first a voltage reducer to cut the the power from 12v down to 6v as the motor is only rated at 7'2 v
chris
OH Cheers Sue yes we throughly enjoyed our evening with you as you are a very easy person to talk to an with an easy goin an if you want a hand to get the fridge an frezzer just txt me an we will come an get you an take you there for you to have a look an if you dont like anything thats there no problem
take care stay safe ps wirein got put back a bit as some certain moggie thought she lay all over my bench an when i tried to move her she lightly bit me as a warning to leave her be so had to wait till she got fed up an thank goodness jen came to the recuse by callin SNOWBALL sayin food up then i dint see her for dust lol
chris an jen
Hi Chris and jen.Thank you for your kind words ☺️. Bless her snowball well cats do like to play meow.
Thank you Chris for helping me with a fridge freezer but I'm getting mot done on car first I thought. You jeen and me we do have a laugh when we meet..... Sue
Chris
I've said it soooooo many times in this build already and no doubt will say it a lot more before you're done but......
Quite simply stunning!!!! :surprised: :surprised: :surprised: :thumb2::thumb2::thumb2:
There are a whole bunch of exceptional modellers on here who produce work that I marvel at and can only dream of achieving one day but what you do really is quite something else.
Keep up the brilliant work.
ATB.
Hi Chris and jen.Thank you for your kind words ☺. Bless her snowball well cats do like to play meow.
THATS OK Sue an yes we do have a good laugh an lookin forward to when we pop over to see you again
chris jen
Chris
ATB.
OH THANK YOU Andrew for your kind words sir an yes i'll be very happy if it all works but will find out tomorrow it will a nerve rackin time when i come to swithing it on an trying the R/C have to have a nerve tab lol
cheers chris ATB
Hi Chris,
It is good to see that you have avoided the use of "chocolate block" type connectors, which so many r/c modellers use. Some years ago, I had an electronics friend and business owner (sadly no longer with us), he would never accept "choc blocks", for the installation in models. He would always insist on mechanical crimp or solder and heat shrink joints. After discussing the subject with him, I always avoided "choc blocks" in my r/c models. I never really knew the technical reason, other than wanting to keep a tidy installation, as you have done in this model.
Tony
Hi Chris,
Tony
HI Tony yes i dont like them either them ole choc blocks as sometimes with them when you screw down the screw onto the wireing it breakes the wires so a bad connection an
chris atb
