AN the bridge is now begining to look like it should overall veiwIMG_5054.JPG
Looking good Chris, love the attention to detail, do not forget the other half:tongue-out3:
Yes don't worry Bob jen taken care of ? oh you mean the other half of the ship lol ;) :smiling: yea I will when I get that far but for now still on that bridge s/s an thanks for droppin in Bob NICE TO SEE YOU
CHRIS
NEXT pics drawin in the bloomin bridge windows as that's what ive been doin all day an it was a s*d to get right so they all match in size an straightness ive drawin them in an rubbed them out six times before I got it right IMG_5059.JPG
port side angle view an now tomorrow will be a nerve rackin day as it will be now time to drill out an file out the windows to all the same size to the plans
Looking good Chris :thumb2:
Goodluck with the windows :astonished:...
Steven
Do you "chain drill" the windows or just the corners then saw them out?
Rick H.
HI Rick yea I will chain drill the windows out with my mini Dremel drill then usein small needle files file them down to the lines but must make sure I don't over file over the lines then as I 'll be right in it as it will be a job then tryin to get them all to match to the plans cheers for your intrest in the build
chris
Steven
An hi Steven thanks for the good wishes on doin them windows as im gonna need plenty of luck to get these windows right as one sharp slip of the file an its gone pear shaped so I must be very carefull doin this but im in no hurry so if I do a few windows a day I get there in the end all I ive got to hope I don't get the shakes as getting old all best
chris
That superstructure is ceratinly shaping up now. The bridge windows look as though they may need support as the frames are quite thin once the windows are cut out. It certainly does look quite a task to plan, draw and build all those windows, angles and facades - bravo on the job so far!
Paul
Paul
HI Paul well ive got some more pics to post of that bridge an no Paul The bridge windows look as though they may need support as the frames are quite thin once the windows are cut out. well they turned out ok no supports needed
chris
UPDATE on the cutting out of the bridge windows an it all went fine its just patience an more patience an I dint get the shakes once so im a happy bunny 1st pic now starting to cut out them window by chain drillin an it looks quite rough but it will get better as I progressIMG_5061.JPG
nxt pic some of the windows on the right side have been filed out but not 100% IMG_5063.JPGas will do these propeperly at the end
AN some views of them all done thank goodness it all worked out ok as one slip of the drill or file an it would have been very awkward to put right an the glazein in the windows will be fitted in after the bridges have been sprayed in their top coat paint in the near futureIMG_5064.JPG
an a overall view of what I got so far an I forgot I will tomorrow have to cut out in the bridges the four doors IMG_5068.JPG
