- Joined
- Apr 27, 2018
- Messages
- 15,229
The undercart looks quite skinny hope it's up to the job.
HI Scottie yes it is quite skinny but i gave the main gear a bend test an its quite strong so dont think it will collaspe with the planes wheightThe undercart looks quite skinny hope it's up to the job.
HI Geoff yes i think you are right or bits out of the scrap bin lol but its quite stronge so should hold the planes wheight easy but tomorrow ive got to see if i understand how to build the thin bits an where they goNow that’s what I call a project Chris
The undercarriage looks like they used left over ships radar antenna
Geoff.
THANKS Geoff yes took some working out how it all fitted as the instructions were useless sayin some parts are ommited lord knows why as to see the whole undercart would have helped greatlly but no so it was just keep studying the pics of the real thing an luck CHEERS GEOFFNicely done Chris
The undercarriage looks very impressive, well worth the full swear box
Geoff.
HI Joe thanks sir yes that landing gear was a hell of a puzzle as i dry fitted it several times yesterday near whole day tryin to find out an LOOKING at the real planes gear but its fairly dark under them big wings so trying to make out how this thing all fitted togeather was more luck than my efforts but i would not give up an once i got one togeather then the other one was easy all i had to do was copy a left an right phew an the nose gear was easy so tommow i'll try an fit the units in the bottom wingGood work on the landing gear legs Chris. Bit of a puzzle, but looks great now.
HI JIM cheers sir yes it really got me scrartching my head as i also have never come accross such a complex undercart as this must be a real headakce on the real plane for the maintance crew but tony yakface on here warned me that was goin to be a problem as he built this aircraft yrs ago so i had a little idea that was goin to give me a headacke an it did but stuck at it an looked it from several angles until i could get a vauge idea on how it went togeather OH BOY needed a nevre tablet after this lolWell Chris that undercarriage is one of the most fiddly bits of a build I've seen. You make it even more so by adding lights. So well done Sir, give yourself a pat on the back.
