Boatmans showtime phantom in 1/48th scale
boatman
Well-known member
HI ALL well ive been sent this phantom kit by a very kind richard 48 to get my mojo back as not got a kit i want to do at the moment an hopein to try an light it up with 2mm leds but on closer inspection lookin at the wings its seems the makers have made the wings ends solid about 1mm thick an not in two bit so i can run my nav lights wires through so i may have a go at doin it but goin to be tricky as when burrin out the wing i dont want to go right through it so see how this goes but cant start on it proper yet as waiting for spray paint to come from my local model shop but for now some picceys
many thanks Richard 48 much appreciated so till the paints come this build is on hold
chrisb
Good to see you back. Always enjoy your builds. Very nice of Richard to provide the kit.
HI Jim yes good to be back as mojo is feelin better an yes Richard is a true gentleman for sending me this kit till i get to hannants to chose my main big kits as im hopein also to get the kit of the 1953 WAR OF THE WORLDS MARTIAN WAR MACHINE as ive sent off for the lighting kit so that should be something different as ive always wanted one
CHEERS Jim hope you an yours are well
chris an jen
The Phantom is one of those aircraft that just looks right. It will be nice to see what you can do with this.
Hope you enjoy making her Chris.The martian war machine sounds great.I saw War of the Worlds performed at the 02 with Jeff wayne and it was excellent.Music and lighting was amazing.Ive seen few different kits of them at shows including 3D printed alien creature and machines.
Glad i helped get your model mojo back a bit.
All the best from Richard
CHEERS Colin for your reply
Richard48 (QUOTE)
AN Many thanks Richard
AN THANKS Steve
yes guys this kit is goin to be a challange to try an fit the nav lights in 1 due to how thin the solid wing is an 2 i have hardly no idea where the lights are on the fusalarge so i will have to do a bit of reseach an hope i can find out maybe some pics on line an colours
CHEERS ALL
​​​​​​​chrisb
This should be a great project Chris. I look forward to seeing the colourful markings 👍
HI Joe yes hopefully i'll be able to build it with lights but will see on that an yes i love jet planes in colorfull markin as most of them are so drab an yes hope you will jion me on this journey of this plane build but would like more info on where the lights are fitted an their colours
ATB SIR
chrisb
Looking good Chris,
would it be possible to 'scribe' a wide groove into the bottomside of the solid wing? Then perhaps use that type of wire used in transformers to power an smd Led light and fill up the groove? Looking forward to your build, have fun!
Looking good Chris,
HI Steven hope you are well an yes all what you have said im goin to try an do but not scribe the wings will have to be burred out to take the led s wire thickness an they are very thin as ive been havin a good think on this as a boaty mate has sent me a letter this morn to say he thinks its possible to fit a 1mm thick firber optic in the wing but as i treid to exsplain to him when he poped over to see me that the F/O is as thick as the wing itself so no go but he still sent the F/O But if im patient i think i can fit the leds in my way just got to be carefull so Steven many thanks for your info an reply very much appreciated
ATB CHEERS
chrisb
Looking good Chris,
HI ALL an steven000 well i gave this quite a bit of thought an what you sir suggetted about scribein a grove worked well thank you sir as dint need to do this on my big kits an after scribein i fitted a small burrin bit in my small dremel an gently burred out a grove big enough to take the 2mm wires an led was a bit fiddley but i managged it now some piccys IMG_0660.jpg
an here fittin the tiny 2mm led in its wingtip place an this was quite fiddley to do an its here still gluein so looks a bit out of place till i used my finger tip to push in into place now to run the wires down the wing an glue in place so it looks like it is goin to be possible to light up this small plane IMG_0662.jpg
