Ill follow along.My fingers been hovering over the buy it now button with this one for a while so interested to see how it goes together.
All welcomeI will follow along if I may.
Great to have you along JimFollowing with interest Brian. Love these turn of the century monsters.
Good luck with yours Dave I'm still a beginner at these so out of the box it isI've the Trumpy 1907 Dreadnought in the stash, but as is my habit, I'll be waterlining it - not easy, as all the cross bulkheads will need cutting as well - I did consider buying metal barrels, but I found the kit parts were just as good!
Interested to see this come together……love the WW1 early battlewagons, and this one is the daddy of them all.
Tim, John your most welcomeBrian I'm in as well,not really a floaty but Chris got me interested. Looks impressive.
I also have the Trumpeter 1/350 HMS Agamemnon in the stash & that has a complete set of railings! I did an inbox review of this https://www.scale-models.co.uk/threads/hobbyboss-1-350-hms-agamemnon-inbox-review.40622/.A bit disappointed with the kit there is only railings for 01 deck and not the main deck, but as you can clearly see from the box art there is railings on the main deck :unamused:
The instructions say no railings but box art says railingsI have ordered some 1/350 royal navy Eduard railings
Thanks for that I have ordered some as spareI source my 1/350 PE railings from Aliexpress https://www.aliexpress.com/item/100...3!sea!UK!133278962&curPageLogUid=A34dsKoDpYBl - theyr'e generic railings, but are applicable to all ships! - Cost wise :thumb2:
Pull up a chair Graham, your 1907 version does it have railings for the main deck ?Hi Brian
i have the trumpeter 1907 version under way (but currently on the back burner), I have water-lined my version and am adding a fare bit of aftermarket product so going at it slowly. Will be watching your build with interest.
Hi DaveI've the Trumpy 1907 Dreadnought in the stash, but as is my habit, I'll be waterlining it - not easy, as all the cross bulkheads will need cutting as well - I did consider buying metal barrels, but I found the kit parts were just as good!
Not yet, but it will do!!!! Will send you a couple of pics of my build in it’s current state.Pull up a chair Graham, your 1907 version does it have railings for the main deck
hi BrianPull up a chair Graham, your 1907 version does it have railings for the main deck ?
