Britsh 25 PDR. Field Gun & Quad Gun Tractor
Steve, good choice on giving it a rest...watching a group of burly guys bending over in a scrum than yourself bending over the carpet is much better. :smiling6:
A good R & R in between building is always good.
Its from Armourfast. Looks like a Panzer III Ausf L or a hybrid of various Ausf's. Very little detail on it and no instructions or decals. I decided to build it as a rest from fine detailing, research, scratch building etc and to use as a practice piece for the new painting techniques I will be using on the main build. Not sure of its scale but its 1 70ish.
Should be 1/72. Armourfast isn’t exactly the best easy-assembly kits you can buy — the Italeri ones (look at the recent StuG III thread for an example of one) are far better, in my experience.
Hi Everyone
:smiling2::smiling3::smiling5::smiling:Brilliant Richard and a cracking result to boot:thumb2:
Cheers Jakko
Has your compressor got a water trap? Have you drained the tank?
Looking splendid thus far. I admire your dedication with the numerous extras and embellishments.
Afternoon mate,
A very long, interesting catch up! You’ve put In so much work...truly impressed with your additions buddy:thumb2:
I have a little experience with fault finding on Pnuematics ( 25+yrs)....that is indeed a moisture separator on your compressor. Highly doubt moisture in your airline is your problem. Moisture will occur in compressed air systems, particularly if your ambient air is moist so it’s always good practice to drain your tank every once in a while.
But if you still think there may be water present, take the airline off the airbrush, put a dry piece of kitchen paper over the airline and let it blow for 5 mins. If the paper towel is wet, there’s your problem.
Looking at your green spray lines on the PzIII, and the way the paint has spider legged out, I think maybe your paint mix is too watery or your pressure is too high? Not being familiar with you comp/airbrush I might be way off...but it’s a starting point.
Hope this helps
Nothing like a quickie to keep the enthusiasm going, that little Cromwell I built was like that, no additions just throw it together and paint.
There does look to be some water in your moisture trap. Have you drained the compressor tank? ( Brass valve underneath on the opposite side to the labels ).
Really top drawer stuff Stevie!! Your work is fantastic and time consuming. In the end this thing will be so fine. Just don't get too carried away with the dark side or you could end up doing an Anakin on us…….
Allen
PS, sorry I can't help out with your compressor buddy...
Hi Steve, Just had a read through from the start, impressive detailing & scratchery.
The airbrush problems could be water drawn in from the atmosphere getting into the water trap & down the tube to the airbrush. There should be a valve on the bottom of the water trap to release it, or just turn the pressure valve to blow it out, I've had the same problem. Adjusting the pressure or the thinning of the paint may fix the paint problems, just have to experiment with it.
Thank you all for your help with the airbrush. This is where I am at the moment.
Firstly the rear was opened up and cleaned out. The whole of the outside of the compressor was then cleaned thoroughly.
The pressure valve was taken out and a cloth inserted inside to clean out the reservoir but it was dry
Next I cleaned out the hose and there was a bit of water here. So I took off the old hose and put on a new one. No matter what pressure it was on the air flow was not consistent out of the airbrush end of the hose. It was like a constant putt putt putt putt. Dont know if it is supposed to be like this
I tried Vallejo and Badger acrylics in the airbrush. I also tried .5mm and .3mm needles. I also tried a variety of pressures. However what ever I did the result was the same. Paint splatters to start with then into a cloudy line which turns more into dot dot dash with the irregular airflow and then more blow outs.
Any other ideas would be greatly appreciated but I am thinking the compressor is knackered
... it looks like there is water in your air tubing..... maybe there is a leak ??
Just caught up Steve and the scratchery is fantastic, love the springs.:smiling::thumb2:
Sorry to read about the compressor problems, I'm no expert either but judging by your observations maybe the shut off valve is malfunctioning or it might be the motor...
Looks you have a membrane compressor, maybe many times of usage near the time-limit of running it have worn down the motor.
Have had the same many years ago with a basic Revell compressor...
Maybe take it to a repair shop?
Thanks again everyone. Si is the main man and has provided me with this link link that showed me how to strip the compressor down and clean it out. Top man:cool::cool:. Many thanks:thumb2::thumb2::thumb2::thumb2::thumb2:. I now have no issues and greater control on the air pressure as well. This is how it was done
I took off the top of the compressor and it was full of crap so this was cleaned out with a brush and a cloth
The next plate was cleaned off. The silicone plug was very carefully lifted up and the crap and holes underneath were completely cleaned out
View attachment 320951View attachment 320952
Under this plate was a small plate. As you can see it is slightly bent up. It should be flat covering the hole underneath. The black housing around this large valve was taken out and cleaned thoroughly as well
So the plate was removed cleaned, turned over and screwed back. The whole thing was then reassembled. I am not very good at this sort of stuff but it was very easy so if I can do it anyone can
Here are the results. No blow outs and a lot better control. I just need to mess around with needles and pressures to get those fine lines perfect
The strength of the forum has shown through today. Thank you to everyone for your help and support
Top news Stevie!!! I guess you picked the right day to give up sniffing glue. I hope the probs are gone for good.....
Really glad that sorted your problem:smiling4: credit to the youtubers sharing their experience.
I’ve been a machine technician since I turned 18 (43 now), deal with all sorts of breakdowns and spend a lot of time fault finding on pneumatic control systems, steam pressure controls, vacuum systems etc....I don’t profess to know everything but I do know a spec of dirt in the wrong place or a dry seal can disable a state of the art £500,000 machine in seconds!
Again I’m glad your sorted....looking forward to seeing some paint flying soon:thumb2:
Well done young Si.
Personally I'd have.....…...
yes you guessed it set fire to the b****y thing.
I can see every one now stripping down their compressors. Glad the compressor is working again.
There is one thing you should do Dr Rivet, and that is to get a " Catch All apron ". This seasons must have for all modellers. I myself use one and it had saved me countless hrs of examining the floor. Great work Steve, how on earth you do it is beyond me. :thumb2::thumb2::thumb2:
John.
