I've been in a slump on the scratch-builds, and decided it's time to start the big PBY boat; I will build as a PBY-5, as per Destination Tokyo, which was much of the inspiration for this particular plane. The PBY series and the Clipper flying boats are my top-two favorites in flying boats.
My last balsa kit-build was sometime in the early 1950's, so this will be quite a challenge! Only started one "rib and stick" model back then, a Russian MIG which I could not finish as I couldn't understand the directions for attaching the wings! This one I hope to finish without too many mistakes!
The official estimated build-time is 60 hours; I expect to take about twice that long.
I started with the 2-piece fin/rudder, but would have done better (after so many years out of circulation) to start at the beginning, from A to Z; I decided to start with the fuselage (the first step in the instructions) next.
Kit parts:
Here the plan is pinned to a home-brew work board:
Next, the outer framing is pinned down, and the core built by cutting 1/16 inch stock and gluing together over the plan:
The ribs, being small, cannot be pre-scored, so must be carefully cut-out by hand from the 1/16 inch balsa pre-printed section, then carefully cleaned up:
I then cut apart on the printed lines, which turned out to be my first mistake! The two-piece construction requires custom cutting, and the text was not clear on this point in the directions.
I had to glue back together and re-cut before attaching to the core frame. Here is the port-side, with leading-edge block and ribs attached:
Another view of the same:
The completed 2-pieces, fin and rudder. Hinging will wait until later.
Next I will be starting the hull; formers are cut and I'm in the process of preparing them. Photos later when I get the first step finished.
I'm building as a static display model, but was a bit incredulous when I found folks building flying versions from the same kit . Here's a link to a forum discussion with two videos of flying builds; check out #361 at page top for flight off of grass, #365 down the page for a flight taking off from the snow.
One Cat.. no bears.. Guillows PBY - Page 25 - RC Groups
Regards, John
Kit parts:
Regards, John
