Burnishing railings?
BattleshipBob
Morning
Just cleaned the railings with IPA then usibg burnishing fluid, same as i use for metal tracks
However they have been soaking for 10 mins, nothing, was excepting them to go a dark colour??
Can someone help??
Bob
Are the railings brass? - I think that the burnishing fluid is usually for white metal parts so the chemical reaction would be different with brass
Hi, it is working but taking very long compared to tracks
Is there other burnishing fluids or methods?? All new to me!
Hi Bob
I didn't know it was available for brass. Let us know how you get on with it please.
Blackening agent is available for most metals. They are usually based on Selinium dioxide and/or copper oxide in an acidic solution. I used to use Birchwood Casey gun blue for my railway stuff, mostly because it was cheaper than the dedicated railway modelling gunk from Carr’s. I found it worked with all metals.
If it’s a bit slow to darken Bob, warm it up. It will speed up the reaction. Don’t over heat it though, being acidic you don’t want it to boil.
Left for ages but patchy. Will leave and use the proper stuff
Might still be greasy on the surface Bob. Give it another dunk in IPA then a dunk in white vinegar before trying the metal black :thumb2:
