I have been using the Flex-i-file one for a while now and found it great, cleaning was easy, just a wipe on paper towel sorts it out, but if you forget then I found a craft knife point to clear out any hard glue from between the forks. Well this all sounds fine until the other day one of the fork prongs broke off. I thought well just order another one, but ordering just this with postage etc was going to be expensive. I did some searches on the forum pages and found a trick of pushing a sewing needle into the end of a dowel and then snip the end off leaving a fork to pick up the CA glue. It works brilliantly. I made a couple, they cost nothing (wife had some needles of the right size and I found some dowel in the garage). The article I found the tip in was from 2010 so good on you John for keeping all this information available.
Gwyn
Gwyn
