- Joined
- Dec 28, 2023
- Messages
- 2,924
- Location
- Swale Kent UK
- First Name
- Peter
I happened to see something made from clear epoxy resin today, and I wondered if anyone used it at all?
Its the sort that comes as a two pack, eg: resin and a hardener which is then mixed and apparently you build up layers let it set, add another layer, etc until you get the depth you need.
It looked like an ideal candidate for using as deep water, as it seems to set very clear.
But, I did notice some small bubbles, which although small, could be out for scale if used for something very small scale, eg: ships, etc.
Is there a way to get it to set without bubbles?
If its doable I am thinking of using some for a small dio of some sort involving deep water.
