CDWs' Hummer 1025
Got it sorted at last
Was going to do the cargo version but this had more appeal when i saw it.
Am aiming to do it in black, green and sand camo and will display it doors/bonnet/boot open so the interior is visible, to which i will add some scratch built bits and other items.
Here's the box/sprue shots with the wood base that Polux has requested it to be displayed on.
View attachment 56474View attachment 56475View attachment 56476
Very nice choice Colin!
Well.... As you are a scratch building addict (see your under nick ;) ), I will wait another of your great models!!
Good luck mate!
Polux
Ps: are the interiors Ok? Are or seens a good kit?
The interior is a little sparse, it just has basic seats and controls but i think i'll be able to improve it a bit.
Looks good so far will watch with interest for the scratch building, hopefully I'll learn something from the master ;) no pressure Colin lol
Well i had a look at this properly today and there's a bit more work involved than i thought to display it as i want to (i.e. doors/bonnet open etc)
The engine only has the lower part in the kit as thats all to see if you look at the bottom of the built model ... so it'll be t'intergoogle to find picture of what the top end looks like.
The side doors are molded in one piece so i'm going to have to cut the doors out and then scratch the frame work for the chassis.
The interior is quite sparse but as it's a military vehicle thats expected, there seems to be just a couple of levers and braces to be added.
All in all it's a good job we've got 6 months to do it :) :)
Excellent Colin. I've got the same one as you and will be shamelessly cribbing as you procede :)
I'm pretty certain that you'll know a lot more about these things than I do!
That'll be two of us on a slippery path then :)
Made a start on this.
Got the chassis made up and have painted the floor pan in its base colour, then will weather it so i don't have to work around the chassis when it's glued in place as you see from the dry fit in the last picture.
The chassis will be flat black as per from the assembly line weather-proofing, the reference piccies i have for the camo pattern i'm attempting show no extra paintwork to match the body.
View attachment 56752View attachment 56755View attachment 56756View attachment 56757
One thing i have noticed is my destructions tell me to put the front anti-roll bar t'other way up from what Graham has his, but cant find a real image at the mo to confirm.
It seems i'm going to have to build most of the body up so i can get an idea how much room i've got to scratch the engine. found a picture of the V8 to reference and it's pretty much a plastic cover with some bottles, pipes etc so not too hard. i'll be adding cables and a few pipes to increase the detail. The air pipe will have to be routed all around the engine to the snorkle base on the model.
You are teasing me now Colin, im dead set on getting a Hummer this year though im still enjoying my 6 wheel Dodge Ram.
Nice work though mate.
Andy
Got a bit done on this this afternoon.
weathered the underside, fitted fuel tank(?) then added the sides and inner wings.
View attachment 56883View attachment 56884
Painted the chassis and only weathered it to be muddy as it's a newish vehicle.
Fitted brake pipes (although these won't be seen when its on its base ..hmmm sometimes i think "why bother" :) )
This is how it looks at present, just have to weather the new added parts where needed and add the exhaust pipe when it's dried.
Nice one Colin. Don't take any notice of what I do, I am known for making up as I go along. Roll bar on mine could well be wrong! Great start bud.
I hope I'm not to late, but that motor, looks like it might be from a Hummer, the civilian car, not a Humvee, the Army one. The military one is a bit more robust.
Loads of lovely photos here:
HUMVEE Maintanance/ onderhoud « HUMMER huren
your cracking on with this build buddy and your doing an quality job buddy
\ said:
I hope I'm not to late, but that motor, looks like it might be from a Hummer, the civilian car, not a Humvee, the Army one. The military one is a bit more robust.Loads of lovely photos here:
No you're not too late mate:)
The site that i found that picture on said that that " H3T - Alpha" engine was fitted to military and civilian vehicles.
However the link you provided lead me to find this .... much more like what you'd expect for an army engine .... a bit more work needed to scratch it up, but it'll look much better eh?
Ta muchly Ian.
after a few hours surviving the apparent ice-age conditions (i.e. nipping to shops and playing snowballs with the dog:)) i got to the bench
weathered the interior a bit as a start before adding all the interior.
Spent half hour or so separating the doors, picture shows before and after.
Got the seats covered in laggers tape to give a bit of texture, painted them up and stuck them in position.
View attachment 57043View attachment 57047View attachment 57048
as the bonnet is going to be open i've had to stick the lifting rings on the chassis as they would be in reality and not just glued to the underside of the bonnet in the case of the model.
added the windscreen and cut away the mounting for the snorkle that was moulded in the bonnet and fitted in position. there's enough room under it to fit the hose i'm scratching up with the engine.
View attachment 57049View attachment 57050
That's a fantastic and good work so far!!
Is coming on very nicely colin!
Had an afternoon trying to create seatbelts, this is the end result. research indicated that the early models had no passenger restraint then they added three point belts in the front and lap belts in the rear which is the era i'm going for (just coz it looks ok really :) )
Also took some wires from the back of the radio through the bulkhesd under the dash for connecting later to some engine electrics, and added the side struts so the belts attach on the inside and the rear door hinges have an external fitting point.
View attachment 57121View attachment 57122View attachment 57123
