Chris' F-Toys 1/144 MiG-21 F conversion
Steve-the-Duck
Chris
Medway Towns
Well, this time around, not a prototype (though there's more of them to come), not a Chinese licence built -21 development. but an actual, proper, MiG-21
Okay, so it's the initial limited pre-production prototype, but there you go
F-Toys have a huge range of 1/144 aircraft, released in limited run, blind box format. Bought sealed, you're never sure which of that particular series you might get, including a couple of hidden specials. Bought in cartons, you're guaranteed to get at least one of each of the series
The MiG-21F was the earliest of the service models, of which probably only around 30 were built, before the mass produced F-13 appeared. There are a few small differences, notably a narrower tail
Cutting time, again. And yes, it is another silver MiG. I really ought to do some in camo schemes, as there are, literally, hundreds to chose from across the -21s service
And here we go, almost the only major difference between the F and the F-13, unmodified at top, narrowed at bottom. The F still had both cannon, so that's to be added next
The F-13 is so-called because it was specifically built to take the K-13 AtoA missile (the one known as Atoll in the West). The port side cannon was deleted to save weight, for the missile pylons. Apparently
And now, to give you nightmares, the completed, three part (bucket, seat, panel) cockpit
Just need to add some belts and some switch detail! Ha ha!
Can't tell if there are actually dials on that panel!
Goddess, I hope not
The magnifier is one thing; the sausage fingers are my problem. That and my complete lack of any musical talent explain why I am not a pianist, I guess.
How many variants are you planning?
All of them.
Well, not all the Ye-4 and Ye-6 sub-variants (which is 2-3 of each)
Thirty-three, or therabouts!
Hopefully, also, without going back over ones I've already 'finished'
Actually, it's thirty-eight, and does include the Chinese ones.
It includes a fair number of unusual prototypes, all of which are, in some shape or form, a MiG-21
I'm tempted to some multiples of particular types, as there are some pretty / odd / pretty odd schemes out there. Like '007' the Israelis 'acquired' and then gave to the Yanks. There's a blue Cuban one, as checkerboard Croatian UM, plus any number of obscure users in Africa and Asia. Indian air force schemes would keep me in MF and Bis schemes for the next ten years, even with my current production rate!
There are, indeed, straps moulded onto the seat. But no dials on the instrument panel (praise Athena!). Just a few spots of colour to mimic what's there
The model does, just about have one gun bulge, but it's practically invisible, more of which later. So, these started life a s a pair of 'Atolls' from the Trumpeter J-7. Still going to need a I more shaping. The F and F-13 have a prominent for'ard airbrake fitted to the gun bulges, but I'll probablyadd that with colour rather than an overlay or scribing
Put a bit of weight in the fore part, just in case it doesn't sit right. Might get some of that Liquid Gravity stuff, but for now I've plenty of bits of white metal off-cuts. And a pack of heads that fit too..
Fuselage halves together. The cockpit detail is practically invisible with the canopy on, but the hole behind the seat is still obvious. I have no pictures of what's actually there on the F and F-13, right under the canopy rear, so I've been faking it with shapes so far. It's not obvious from this picture but there's a gap around the whole cockpit bucket when it sits dead centre. Invisible with the black surround, so good job none of these have a blue cockpit!
Wings on, and minorly gappy, but a run over with putty, and on the fuselage seam, should be okay. The model is very slightly undersize in a few places, and maybe even be 1/150th. My calculator tends to confirm that. The ventral strake is definitely undersize, so that'll get a a strip added. The ventral tank doesn't seem to have been fitted to the F, so those middle mounting point holes need filling
So, they're still visible even in this poor pic, but there's a prominent intake for'ard of the tail planes, and a bulge where the earlier prototypes had the tail planes mounted. I'm probably going to add something there to make them more visible
IMG_3996.webpI've had this a while, and it may get built for this GB, but I'm adding this little beauty to my stack of reference material!
1/72 will seem huge after those tiny kits
Nah, it's fine, especially after the last 'plane I finished was that 1/72 scratchbuilt Avro Aldershot biplane, with a 28cm wingspan. The 'big' MiG won't look that large next to that
So it'll go in a different cabinet
Right, a few streaks of filler, bit of clean-up on the seams, then lots of fiddly bits added; vents, tail fairings, enlarged strake, boom, pylons, and nose wheel doors.
The kit nose-wheel doors come as a single piece to slot into the bay, with the wheel behind it. They look very small, so a couple of strips of plasticard suffice as replacement, which may get shorthened a tiny bit later
I could have just removed the strake and made an enlarged one, but the shim and filler worked fine.
I did add the central pylon, after removing the ubiquitous centreline tank, as all the drawings show it in place. The only photos I have of actual Fs have the undersides in shadow so nothing can be seen. I removed the Atolls from the pylons, and used the noses for the tail fairings! One of the two F photos I have shows missiles on the pylons which look like Atolls, but the F wasn't set-up to carry them, apparently only being armed with SNEB pods. The F-13 was so named as it was able to carry the K-13 missile (Nato coded Atoll)
One thing I am definitely not adding is the little fins on the boom, even though they are available in etch! Even I'm not that crazy detail freaky! Though I have considered adding the odd-rods radar aerials, like I did with an Su27K, in this scale...
Probably paint next. Lots of different shades of metal
Paint!
Tamiya Bare Metal Silver, rattle can, overall. No real marks or blemishes to deal with, so...
On with the many shades of silver, oily steel, gunmetal, and aluminium
The dialectric panels and shock cones are all green on these little F-Toys kits. And some of that has spread to one of the wheel wheels. Touch-up time. I've painted in the various airbrakes, two on the gun pods, one behind the centre pylon.
Added the stars and numbers, and the latter took three attempts. I was going to name this 'plane 08 as it would be the eighth in my series of -21 builds, but there was an F marked 01 in the Central Airforces Museum in Moscow, not that I'm doing that particular 'plane. I say was, because my books are thirty-ish years old (this picture is from Bill Gunston's 'MiG-21'). The most recent photo I can find from the museum, dated nine-years ago, shows 01 now with a solid rear canopy. So, possibly it's had a restoration, though it is still an F otherwise and not an F-13.
Last bits
On with ther main wheels, no problem. The nose wheel tho', which is very delicate, bent when trying to push it in . Miraculously it didn't break bending it back. Bit of a blob of varnish on the dialectric panel, in m y continuous determination to get it to go matt
Aerial replaced with a bit of strip shaped. The kit piece is woefully undersized, and it mounts way too far back. The light shining through still shows the brown of the cockpit framing, from the original kit camo. A little touch-p and it's fine. Fitting the canopy, there are two blades to lock it into place, hence the gaps at ther sides of the cockpit bucket. That will require some work when I do the F-13 with an open cockpit
Whether that is next, the Ye-2A or the Ye-150, not sure quite just yet.
There's always the 1/72 F-13...
So, over to the completed thread
