Chris's 1/144 Ye-4 Conversion
Steve-the-Duck
Chris
Medway Towns
And on to the second MiG-21 prototype. And I haven't even finished the first one yet!
The Ye-4 is the delta-wing prototype, which lead to the Ye-5, Ye-6 and finally the service -21. All of the above are on the cards
The 'kit' is part of a set from the Area-88 manga and anime, which is the story of mercenary pilots flying just about every conceivable 1980s aircraft, in defence of an East African desert kingdom, which most be richer than Saudi Arabia with all the 'planes they have access to. Likewise, the rebel faction have enough money to deploy an aircraft carrier. In the desert...
There was a series of ten 1/100 kits waaay back, from the series, some of which were also released by Revell. I think I'm only missing the Tomcat and one other from the set. I've no idea how big the 1/144 range was
So, most of what follows is the work of one day, while paint and stuff is drying on the Ye-2
First off, a lot of the raised detail is removed. No idea what all the rivets top and bottom of the wing are supposed to be
In order to move the tailplanes up, what turned out to be a single piece had to be unceremoniously removed. With fortunately only a little break. And easy enough to repair
Plus some extraneous detail needed removing. Interesting that there's a housing on the service version that corresponds to the higher mounted tailplanes on the prototype
I didn't put and airbrake panels on under the tailplanes, unlike the Ye-2, as there's nothing visible there on the photos. Must be somewhere...
The prominent later airbrake is removed, plus the mounting bar for the centerline pod
The Ye-4 has 'pointy' delta wings, so that's a couple of bits of 20 thou added
And on with the tailplanes, after narrowing down the fin chord, and removing all the extra widgets (which will be replaced in a different position)
And on with the tail strakes and the underwing fences
Some of the sources debate the point of the underwing fences. The Ye-4 was later modified with several overwing fences. Seeing as the underwing ones align precisely with the later pylon positions, I think it's pbvious whaty they were for
As with the Ye-2, the nose needs to be shortened by about 1 mm, which is easy enough. Will need a little sanding laterIMG_3863.webpIMG_3867.webp
Nose probe is just a piece of 0.5 mm brass rod, and a shim underneath. I'm hoping the rod will be more robust than placcy rod!
None of the prototypes seem to have had doors on the main wheel legs, so that just needed a little surgery
And on they go
With just a little twist to straighten it up before the glue dried, after this pic was taken. Unlike the Ye-2, this kit has all the undercarriage door integral, so no chance of knocking them off
He says with unwarranted confidence!
Well now, it looks like rattle-can Humbrol Metalcote Polished Aluminium is my go to for all the Soviet jets
Not that I'll be able to find any more! Note to self, buy more Humbrol Silver spray cans
Surface, where cleaned up, is a little rough in places, but only noticeable in the big pictures. N ow from some panel differentiation and detail painting, before putting the wheels and canopy on
Oh, if only I could have got a half-dozen of these particular models. Maybe eight-or-nine. Soo much less work than the Trumpeter F7 involves...
Speaking of which, canopy time for the Ye-2
The kit wheels don't have the Russian artillery green hubs, so that's sorted
And once they're on, the main-wheel actuators are added, which aren't in the kit and are only just visible in the photos
Photos show very prominent u/c indicator posts, so that's a couple of bit of brass rod, because I know I would knock them off straightaway if they were plastic!
Added a little detail to the cockpit: the prominent circuit-breaker box behind the seat, a control panel top, and all black colouring. I will get to pretty blue interiors sometime, I hop
The canopy just required a little paint removing from the back, and some framing painting in
The nose number is ahistorical, and is basically to show the Ye- number.
And that's another one done
