Completed Airfix - DeHaviland Tiger Moth Mk1 1:72
Thorbrand
I've been busy this month and this is my second bi-plane and last one for a while.
Pretty much a problem free kit this one, I didn't go overboard on the supporting wire frame and I didn't put the control cables on but I think it looks good enough as it is for 1:72.
4 coats of yellow paint on this one! next time I'll use a white primer for yellow.
The Tiger moth has to be the most humble aircraft of the war, being a trainer and not active in front line combat roles I believe it was also one of the smallest air crafts, see the comparison pics below between the swordfish and the tiger moth. It's tiny!
Very nice work indeed Alex. For the rigging I use EZline, its a thin elastic and very good for this scale aircdraft.
Thank you, I've heard about EZline, must get some as currently I use heat stretched sprue. The problem with sprue is you can't always get each line the exact thickness you need.
Nice one Alex - and great effort with the rigging. I love the Tiger Moth - must make one myself as the camo + yellow scheme would stand out well in a WW2 collection. I bet the current Airfix kit is a lot better than the ancient one I made many years ago.
If you do decide to make one, be careful of the exhaust at the bottom, if it comes loose it's a real bugger to get out again so i would suggest leaving the exhaust as the last piece and stick it in with super glue
My problem with stretched sprue is it always, and I mean always breaks just as I think, it's nearly thin enough. Anyway, nice Moth.
