Completed Dave's PRU XIX Spitfire (Airfix 1/48th)
dave
Brussels
This is now completed and on time.  I have deliberately kept the weathering light.  The aircraft is pictured just before the last ever operational sortie by a spitfire over Malaya on the 10th June 1957.  From my research I gather the name "The Last!" was painted on the aircraft before the final sortie.
Reasonably happy with this although something went a little awry with the canopy, in reality it is slightly cloudy but in these photos it looks like frosted glass unfortunately.
View attachment 259867View attachment 259868View attachment 259869View attachment 259870View attachment 259871View attachment 259873View attachment 259874
Wow Dave I mean wow
I have built the same kit but nothing in comparison to yours.
this looks brilliant ( truly stunning
kind regards
Robert
Lovely model Dave, the finish looks really nice
 Did you flat coat over the canopy? If so you may be able to remove it with some thinners on a cotton bud, followed by carefully applying Future with a brush.
Great build Dave. A shame about the canopy, but it doesn't detract too much from what is otherwise a fantastic result.
Actually Dave, the canopy doesn't look too bad on closer inspection. Did you use model glue or super glue to fix it? That may have caused the frosting. I use white glue (PVA) on mine, it prevents frosting and provides a good filling agent for those pesky gaps between the canopy edge and the fuselage, as you can simply smooth it with a moistened cotton bud tip.
I was thinking of trying that! The canopy was protected for the flat coat but only loosely so some overspray may have occurred.
Wow Dave I mean wow
kind regards
Robert
Thanks for the kind words, but I have a long way to go yet.
Thanks Joe, as said above I may have a go at a little very careful remedial work on the canopy.
Great work Dave it looks lovely, pity about the canopy though.
She looks great Dave. But just have a look at the undercarriage again.
Lovely looking spit dave , the colours and finish are spot on. Im sure the canopy will clean up with a bit of thinners and a cotton bud as mike says. cheers tony
I have done  :o , I cannot believe I did that, undercarriage now swapped around after a bit of work.
