Right, crunch time. I have decided to have a go at creating my own pigments-having done some research it seems that it appears to be 50/50 regarding 'own' brand to bought-some say it works others say it just dollops and doesn't look right.
For this exercise I will getting a cheap-very cheap or second hand electric coffee grinder-maybe with multiple settings as I need it to be as fine as I can get. For the pigments I will be using oil pastels first-something to do with with more pigment less binder. Once ground the pigments will be stored in plastic sealable bottles.
I have also had a go at making my own fixer using white spirit and Klear, just need to work out the %, the white spirit is the carrier that evaporates leaving the pigment in place while the Klear seals it-well that's the idea.
I am sourcing bits and pieces at the moment, hopefully I can expand on this thread with some pictures when I get all the gear and see if it is an exercise worth doing or not.
Any thoughts or ideas are a welcome chaps, if you have done this yourself, any tips?
Si
Si
