Das Boot.
Thanks for the help and advice fellas i can certainly try to scratch build the base and maybe ican put the cmk crane on the top of the structure!
Jon: the figures looks great can you tell me which company makes them and where you find it ! Thanks in advance
I also found from verlinden a gentry crane but it’s for a tank repair however seems like the distance between would fit on the pier but again the wheels would be a problem here it is ! View attachment 311356
I guess scratch build is the only option! Also found this its a german electric crane for harbours ! View attachment 311357
Hi Danny.
those figures are from a set by Andrea and are still available through Historex agents.They are 54mm scale though.
Jon.
Hi Jon thanks for the info but unfortunately I cant find it is by any chance can you give me a link please . thanks Danny
The only ones I found online were thousands of $. Langely Miniatures in UK ? may be of some help in 1/48, as they do a lot of nautical. PaulE
Gary Thanks for the link appreciate it . Also big thank you Paul for your assistance . You guys are super kind ! The search goes on , thank god I only do this next year so it gives me time to collect what I need ! Best regards Danny
Good evening everybody I have an idea so I have been searching all day about the cranes so i took your advice Paul and looking at smaller scales but big structures! So I found this .. the distance seems ok for the rails! I will not use the crane just the base structure and on top i will put the cmk crane which is the correct size 1/35 so I think I give it a go it might work the kit is £10 so if dosent work I don’t loose to much! Like to thank you for all of you for your assistance and help best regards Danny View attachment 311411View attachment 311412
Ah and Jon and Gary thanks for the help with the figures I like them but its not cheap £19 for a figure its a little bit painful I guess! Will see maybe slowly one by one! Cheers Danny
Miguel and Snowman thanks fellas! Miguel unfortunately you have to wait for a while, sorry! Regards Danny
I have also received the crane but unfortunately is a no go! The distance between legs are to small its 7.8cm and i need at least 9cm for the inside track and 10.5 cm for the outside! So back to square one with the crane subject! I was really hoping it would work but again my luck! Anyway I don’t give up !the search goes on , i probably need 1/72 or 1/48 kit! Shame really that no company makes big cranes on rails! If the search fails then no other option but scratch build! Thanks fellas regards Danny
Maybe you could adapt the crane legs with some putty or green stuff? Green stuff is for me the solution to everything hahaha
P.S. my bad, just saw the crane design, i though ot was the one that was posted some post ago.
P.S2 maybe you could use the verliden tank reparation crane as base as it fit on the rails and just add on top the crane that you wanted, only needing some adaptation.
Good afternoon to you all! The collection of the required items has began! The first 2 kit has arrived! Also contacted U-models because I went on there website and it seems unfinished not much to see on it ! So they were kindly have sent me a catalogue and a price list of there products! So I tought i share with you guys you might need something from them in the future! Regards Danny
So that is the catalogue I hope it helps fellas the only page that the site doesn’t allowed me to upload is the price list so if you guys need message me PM and I send it over maybe in an email!
