Das Boot.
Wow another grand dio in the making Daniel, looking forward to see the start of it all.:smiling::thumb2:
For my Kommandowagen I had a spacing of 41mm between the insides of the railtracks and it was 1/35th too.
Good luck finding all the wanted pieces.
One question for all of you! Any of you have built a train before? If yes could you please give me a measurement for the distance between the wheels! I like to know if a train would fit on the pier rails ! Thanks in advance regards Danny
In most countries the standard rail gauge is 4' 8 1/2", or 1435 mm. I think that was derived from Roman chariots!
Just saw Fernando's response after I'd posted, and 41 X 35 = 1435!
Hi Peter
Little bit of info you might be interested in...
Four foot eight and a half inches was taken from coal cart tracks. The chariot measurement was seven foot and a quarter inch, used for GWR broad gauge.....why wasn’t it just seven feet though, what does the extra quarter inch add???
Tim
It appears we have very similar ideas when it comes to floaty things. I also purchased a U VIIc last year in1/87 scale. Think I'll sit on mine a while longer and see what develops with the 1/35 and 1/72 versions before attempting to make the leap.
Rick H.
Hi there Rick i see so you let us do the learning curve first before you jump into it! Hope it all turns out well and you get the idea! Best regards Danny
Hi Daniel, looking at that I would say it is “crane” gauge rather than railway track. The design doesn’t seem correct for trains because the outer relief is superfluous.
Tim
I would assume the rails are for the cranes to go up and down on
View attachment 311326(
(for information purposes only)
Hi Tim thanks it is for a crane but the problem is that no company makes such a crane models in 1/35 i found one from u- models but its no longer in production! Guess thats my luck ! So that’s why I thought I can incorporate a train! But that ideas gone out the window!
Thanks Danny,
By the way where are you going to park this ''Behemoth'' once you call it complete?
Rick H.
I have a spare room for my dioramas ! So it will rest with the others when its done! Thanks again for joining regards Danny
Hi danny
Are there any plans about so you could scratchbuild one? You should be able to source the wheels easily enough....
Tim
I agree with Tim , Danny its quite within your skill to do it. I'm voting for the crane! :smiling2:
John.
Yes, it's only a few straight bits stuck together!
I would check out model railroad sources for quayside cranes in 1/48 & 1/72 scales (O&HO) for models that could be modified to suit. Usually just making bigger doors will work if the model is large enough. PaulE
