diorama / model display ideas
saguy
hello all ... any ideas / suggestions (or current threads to reference) on ways to display models and dioramas ... at the moment i have mine parked strategically through the room at the back .... whilst pleasant enough to look at they do collect copious amounts of dust ....
ta
Hi Lindsey,
I have a glass display case but need to get another one soon as this one is now full. If you shop around you can get them fairly cheap. You can also try and find ex shop display cases if you are lucky.
Hi Lindsay
I'm with Scottie. I have a glass display cabinet with two glass doors. They can be picked up reasonably priced and the one I have holds quite a lot with glass shelves which can be adjusted. I had a couple of extra shelves made at a local glass cutters. Really does keep off the dust. Perspex cases for individual models can work out expensive especially if they are custom made for the model. This one looks nice but cost more than the model and then you need a place to put it.
Hi Lindsay
Nice to see someone of the true faith on here, I’ve followed LUFC since Revie’s day......
If you find a good off the shelf glass cabinet,especially wall mounted, could you post it up? I’ve struggled to find one that is well made enough to keep out the dust, and is also big enough to hold anything bigger that 1/35 tanks,,,,,
Good varnish is water-repellent :) The real trick is sticking the model down in the aquarium with waterproof glue, if you’re not building a Tamiya 1/48 scale tank anyway.
