After having used PE parts for the first time on a tank I wondered if any of you make your own PE?
I tinker with a lot of things and one of them is electronics design. I make my own PCB's (circuit boards) at home with great results at low cost, and I thought it wouldn't be that different to etch a thin sheet of brass than to etch FR4 (the most common type of circuit board substrate we use).
It's not hard to achieve high resolution just using a laser printer to create the mask.
Any of you doing this?
I've noticed that PE parts can be a bit expensive, but mostly they are hard to find, and that's when this question popped up in my head!
I'm going to see if I can find a suitable sheet of brass to test with. I've got sheets of thin copper but in this application brass would be a much better option.
