I came across some casting powder the other day, and a little bulb lit up, that reminded me of an article I once read on making dry stone walls for any scale dio's.
1.Make a mix of your powder, casting,plaster of paris, poly filla etc.
2.Then pour it in a tray, not to thick, then tap the tray to get the air bubbles out.
3.When its near the setting mark, just dab your fingers lightly over the top to give it texture.
4.Then when its dry, just crack them all up into little pieces.
5.Then build your wall, to the style you want, I used PVA glue to set the pieces in place.
6.When you have built the wall, I just mat varnished it before painting.
6.Then when the wall is set, just paint it to the style and effect you want, after you have painted it, you can add pastel or weathering powders, I just airbrushed various Tamiya, greens and browns to give it a weathered out door look.
I hope this is of use to you Dio builders.
Thanks for reading all,
Ray
Ray
