I've decided to do an 'early' Emil to complement the Mk I Spitfire (from the Revell Mk 2 kit) which I recently completed.
I'm not going to do a blow by blow account, though I'll highlight any problems I have in case that might help someone else.
I'm going to pose the model 'closed up' to which end I won't be fitting the engine and will only build the internal bits which have to be built to hold the thing together!
I don't fancy the one option in the box so I'll be doing one of the three options on the sheet, based on the green (RLM 70/71) splinter scheme. I fancy either Priller's machine with the oversized crosses on the wings, or the one with the white tail. Both, incidentally, are marked in these ways because the Germans were having just as much trouble as we were telling friend from foe early in the war.
So far I've lashed together the cockpit:
The only thing not out of the box is the harness from RB Productions.
