I’ve gone on a bit of a favourite aircraft modelling trip at the moment … After finishing the BAC Lightning (well, it still needs paint) I’ve started on a Tamiya 1/72 F4U-1A Corsair.
Here’s what you get in the kit:
I’d never built (or even looked into the box of) a 1/72 Tamiya aircraft kit before, but these parts look really good. Once I started building it, that impression only improved. Here’s the cockpit., for example:
I don’t build many aircraft, but this is more detail than I’d ever seen in an aircraft model this scale, and more than I’ve seen in most of the 1/48 scale ones I built a long time ago. The seat is a separate part from the back plate, the rudder pedals are a separate part, as are the two troughs below them, and the stick with its linkages needs to be added as well. (The rod running backward broke off later when I test-fitted the front and back sections of the cockpit; I managed to glue it back on, but it broke again when I was painting it and flew off somewhere — I haven’t found it yet.)
With some paint on, it looks like this:
I painted it medium green with a dark green wash and light green drybrushing to bring out the details. The instrument panels etc. are black with some grey drybrushing. There’s a decal for the instrument panel, oddly enough covering up all the moulded-in dials, and for the seatbelts, plus a clear part for the gunsight — though most of it has to be painted black, and that means the clear bit at the top appears black as well. Fit the sight after applying the decal, by the way: it goes through a hole in that.
The insides of the fuselage are a bit garish:
Tamiya’s instructions simply tell you to paint all interior areas the same green (a mixture of their green and yellow), but I found on the IPMS Stockholm site that the F4U-1 and early -1A aircraft had the cockpit painted green, but most other interior areas in a colour called “salmon” which was apparently a reddish orange. So, orange with a red wash it was. Similarly, Tamiya says to paint the inside of the engine cowling, the rear parts of the wheel wells, and the insides of the wheel well doors green too, but that site says all these were white (other than the tail wheel doors), so that’s what mine will end up as. I should’ve painted the forward parts of the main wheel wells before glueing the wing halves together, but I forgot, hence the orange paint on the undersides of the wings
