Simple but great video. I can go out and but some thinners but not sure what brand my local shop stocks. But I'm going to assume that thinners has the same chemical compunds. So I'll see what he does. But I have a huge bottle of iso Alcohol so it would be handy if I can use that ?
Water or isopropyl alcohol works with Tamiya. Drying is a little slower with water. Water is OK with Vallejo.I was going to use water :flushed:
Sorry Garry not all thinners are the same, even with acrylics. There is a thread on here that explains it. Will try and find it for you.
Found it thanks AndrewSorry Garry not all thinners are the same, even with acrylics. There is a thread on here that explains it. Will try and find it for you.
