- Joined
- Jan 26, 2017
- Messages
- 2,692
Unfortunately I’ve been making slow progress with the build mainly due to lack of bench time.
I have however managed to sort out the poorly fitting bomb bay by sanding it to within an inch of its life :tears-of-joy:
Fortunately the plastic is quite thick so I was able to get away with it.
It needed some filling and rescribing too but I’m satisfied with the result.
As you can see the main components have had a coat of grey Stynlrez primer so I could see all the imperfections/seam lines easier.
The engine nacelles neede a bit of filler around the joints, I used Perfect Plastic Putty for this to avoid any further sanding.
The seam lines have mostly been dealt with so I will give it another final prime later.
Touch and go whether I’ll finish it for the anniversary date but I’ll give it a good shot.
Thanks for looking :thumb2:
Geoff.
Geoff.
