Some one asked if I could describe the process of rigging a Bi plane, so I will give it a bash. SORRY NO PHOTOS. I did not take any underway. I hope you can see it with good old text!
You will need a few things to get this done:
A pin vice and a drill. I used a 0.3 which is as small as I can handle with out bending or snapping off!
I dubbing needle; a needle with a handle or indeed just a pin in a pin vice!!!
Super glue. One of the instant grab CA type
Wire; For this I used 1lb fishing line that was run through a tamiya paint marker in gun metal colour.
A fine pair of tweezers.
A pair of locking tweezers are hands as well.
A very sharp fine pointed scalpel. Open a new blade and then sharpen it!!!
Build the kit but do not put the upper wing on. Yet!
Paint the kit. If you use a mixed colour save some or be sure you can mix that same colour again.
Now the fun begins: Fine a good reference, or if you cant find any, the box art! Study the runs of the wires, noting what they do and how they are placed and how many there are. On my SE 5a the main wing braces should all be Doubles but hey this was my first attempt to, so they have single wires only!
Once you have established the placing of the wires, its time to start drilling. Go around the plane. Both wings, tail plains, rudder, wheel braces and the like. Drill a hole in the correct place for each wire.
Step 2! Put the wing on the plane!
Next day should see things are set and you can start knitting!
Some will take a long length of monofil and run it through a few places and attach it only at the start and end. Not an option in this demo!!
Thread the line though the hole and secure with super glue. Insert the other end through the other hole and pull it gently tight. Start inboard and work out as this helps the access.
Work in pairs, port wing>starboard wing- etc., Keep a good eye on not pulling to much as you will pull the wing out of line. Then its just a case of working your way from side to side. port-starboard-port-starboard.
I know it sounded easy but in fact it was!The hard part is getting started..
Once all the wires are in place and CA is set. Its time to find that razor sharp knife.
Cut all the loose tails off and if needed sand the spots off. Then TOUCH UP the exit holes, job done.
Any questions just ask.
