gluing these 1 72 poly-watever the stuff is figures
bazers
Hi guys just got box of orion soviet figs to go with a soviet armoured train dio i am building and am trying to alter some of the figs !!!!!tried super glue but no good any ideas ?.
I not too sure what to use. Would something like epoxy resin work? It would probably be a bit fiddley with the size but might be worth a go. :)
that is a hard one, I did try super glue on some airfix one once ad same as you not a good idea,
when i do 1.35, iI pin them with wire then just use putty ,
Done any PVC pipework at home of late?
There's a clue there somewhere.
\ said:
Done any PVC pipework at home of late?There's a clue there somewhere.
Tried that Ian, the trouble is both Polypropylene and polyethylene are very resistant to any sort of solvent type glue. I used to use the solvent glue for making plastic/pvc pipe work joints and thought I would try it on 1/72 figures with no success. The figures are usually soft plastic whereas the pipe is hard.
I believe Loctite make a two part product - primer and glue - which is suitable for those poly type plastics.
This stuff works too:
https://www.eanfind.co.uk/product/K8H9E7BLW2
Gern
