Anywhere they wouldn’t fall off, probablyusually in a rack on the side, but I'm doing a desert version, so where to put the extras which would be needed for the conditions in North Africa?
Panzer IV North Africa you’ll probably find lots of inspiration. Just be aware that you use pictures of long-barreled PzKpfw IVs, since the short-barreled ones often differed from them in this kind of stowage.I almost invariably paint tyres in two goes: half the wheel at a time.wait till you have to paint the rubber portions. The Italeri kit doesn't give poly caps I think so you might have to poke cocktail sticks into the hub and use that as leverage to twist as you brush paint in the rubber lining. Of course the other option is to paint it all rubber and then use a circular template of the right size and spray on the body colour.
Half the width or half the circumference?I almost invariably paint tyres in two goes: half the wheel at a time.
True, I included it mainly because it shows (more or less) what I meant by the length of track on the front plate with a wheel behind it.Jakko, great pictures, certainly gives me some ideas, the middle one may be a bit extreme!
