Graeme's Tamiya Puma
Sure looks a lot more complex than the little 1/48 232 I'm building. Coming on well though.
I like these and have a few in the stash in 1/87 scale. I will want to see how this goes and maybe jump on mine if I can keep the MOJO up! cheers, Rick H.
Andy, Rick, Good to have you along, the Puma does seem a bit of a complex beast, look at the suspension & all wheel steering.
A bit more progress, the interior is in, ok, it's just a couple of seats, steering & gearlevers. Yes two sets, one for each direction! Next the hull top to attach.
Hi Graeme
As Andy noted this is quite a complex kit. That suspension does look rather fiddly and delicate. The turned barrel is nice and gets rid of the worry of warping. Is it fixed with CA or epoxy?
Jim, thanks, the barrel is fixed using CA, the suspension is a bit complex, but went together quite nicely, the steering arms were the worst bit, just needed a bit of patience.
Thanks Paul, it's just finding the time to build it.
Looking good so far. I think you are lucky to have the fiddly suspension. It adds a lot of detail that is missing completely in my scale of choice (1/87). Cheers, Rick H.
Bob, Rick, Steve, Thanks guys. I think the suspension would be very fiddly in 1/87!
A bit more progress, the hull has been joined together and the mudguards fitted, a bit of care had to be taken with joining the top & bottom of the hull with not much to locate them together. A couple of pictures, the wheels are dry fitted for the pictures.
Thanks Guys, I'm going for the three colour scheme, plenty of scope to hide errors!
Still plenty of bits to go on though, bumper, numerous jerrycans on mounts, not to mention a couple of crew.
Not much done since last time, busy with work around the house, a couple of small bits added to the hull, the jerrycans & holders made up, the jack assembled, have to find a bit of time to get on with it!
