Grain of Rice/Wheat Bulbs
Mr Bowcat
SMF Supporter
Bob
London
Hi guys,
Need some help please. I've got a build coming up which I want to install a single bulb in to light the interior. What I would like to do is power this from a battery rather than mains with a transformer, but I'm struggling to find much info on the subject.
As far as I can see, I can get a 1.5v grain of rice bulb which I can run off AA batteries, however I'm not sure if this will put out enought light (it's to light the inside of a turret). Alternatively, I was thinking of a 12v grain of wheat bulb, and run it off a 9v battery.
As I know nothing about this kind of thing I thought I should ask for some advice first, so over to you guys. :)
B
i once lit a klingon battle cruiser using a set of 12 led xmas lights powered by 2 AA batteries that i got for a quid in the post crimbo sales lol.........was easy to use and came with the battery box, and they gave out a lot of light
look forward to seeing your project when you do it
Beowulf just beat me to it
LED is the way to go these days - high light output, no heat problems, low power and last for ages
Cheers guys. The problem I foresee with LED is just the size of the bulb, do they come in the sub 2mm range?
Certainly — just search for “2 mm LED” (or 1.5 mm, or whatever) and you should find plenty. Remember that you may need to add a resistor to the circuit to make sure the LED doesn’t get damaged. This site seems to explain the basics fairly well.
Just looked on ebay and there are 1.5mm ones
Another thing that you can do is use fibre optics if you are limited with space - embed fibre(s) in the model and light from remote location
Excellent, cheers guys, that gives me plenty to go on. :)
