hi all here is my latest (but not greatest) ,the maquette kit of the h.p. herald turboprop airliner. This kit is a reissue of the ancient frog mouldings and does it show! there was so much flash im considering calling it my first vac form!!!! but after tons of filler and fettling it came out ok.The biggest problem was with the decals-firstly there werent enough stripes for the plane ,not even enough for one side!so i had to mask and paint the top 3 cheat lines (not easy when the two thin ones were 1.5mm and 0.5mm ,plus i had to mix the colour to match!) Then when it came to applying the decals most of them broke up on application , so the end result doesnt bear close scrutiny! All in all though it came out not bad but i'd get an aftermarket decal sheet if youre considering this kit. Thanks for having a pike ! ,cheers tony
lane:
